Re: -97 360 magnum in -89 B250
[Re: sshemi]
#2159476
09/22/16 03:33 PM
09/22/16 03:33 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
What engine is in the B250 now? If it's a small block, I would be tempted to swap just the engine & use my '89 parts as needed to make the '97 engine run. I did this with my '96 Mustang with a '04 engine. I re-used my ignition, timing cover and throttle body from the '96 and the '04 bolted right in.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 65rbdodge]
#2160705
09/24/16 10:10 AM
09/24/16 10:10 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The 89 intake will not bolt on the magnum engine the intake bolts are vertical on the magnum. Yes, it will with a bit of work. But trying to keep the 89 TBI system is not worth that bit of work.
