70 HP oil pan bolts #215800
02/06/09 11:30 AM
02/06/09 11:30 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I am trying to restore a couple of 70 hp 440 motors and am short a few bolts The original ones are 5/16 and a little longer that a motor that does not have a windage tray. They have a number "23" on the head. Is there a source for those? What about the new one you can get from Ma Mopar/ I have not looked at the head but I know they are the longer version. They also have a nylon spot on the threads for locking I suppose.
Re: 70 HP oil pan bolts [Re: fastmark] #215801
02/06/09 09:39 PM
02/06/09 09:39 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
These are 5/16" from 1997.
Re: 70 HP oil pan bolts [Re: fastmark] #215802
02/06/09 10:01 PM
02/06/09 10:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
These ?
Re: 70 HP oil pan bolts [Re: fastmark] #215803
02/06/09 10:01 PM
02/06/09 10:01 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
The 23 marking is correct-try www.amkproducts.com
Re: 70 HP oil pan bolts [Re: Paul Jacobs] #215804
02/07/09 02:33 AM
02/07/09 02:33 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Those pics help. The new ones have the wrong markings on the top as I suspected. I dug through about 4 buckets of bolts looking for several nuts that I needed and found a stash of the correct "23" marked bolts that were the longer version. Now for the big question. Were all of the oil pan bolts the same? The reason I asked is because this 70 hp motor that I am building for my Charger was taken apart and had a cam, piston, and intake change. Some of the bolts were not correct. Three oil pan bolts were missing, but in their place I found some just a tad longer. Were they used in the back were the rear main seal cap was installed? Does any one know this one?
