Re: E body 5 speaker AM 8 Track Bench test
[Re: Aar1064]
#2158029
09/20/16 11:49 AM
09/20/16 11:49 AM
Posts: 1,822 Colorado
denfireguy
Colorado
What is the best way to test the complete setup while dash is still out of car. I've tested the radio and 8 track player with just a speaker and all is good but before I place dash in car, I'd like to test everything related to the system in case the Rear Speaker switch is bad or noisy as well as the crossover box. All 5 speakers have been re-coned and I'm not sure I can wait any longer to see what it sounds like plus if there's something that needs to be worked out, I'd much rather do it out of car. All speaker wires have been cleaned up and tested. The dash wiring harness is new.
I was thinking that I could just provide 12V to radio, ground and connect speakers but I'm not sure if the other devices within this schematic would get the necessary voltage.
Any ideas would be greatly appreciated. Clip lead the speakers and crossover boxes into the radio. The crossovers are passive devices and take no power to operate. As a matter of fact, all of it is passive except the radio itself. Put a small screwdriver into the antenna connector (Motorola jack) with your finger on the screwdriver blade. Should bring in higher powered local AM stations. Also should be able to receive FM stations as well. It will not sound as good as it will in the car as you do not have enclosures around the speakers. But the speakers should all work. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Aar1064]
#2158136
09/20/16 03:43 PM
09/20/16 03:43 PM
denfireguy
Colorado
You can check a speaker with a flashlight battery and clip leads. It should pop with contact to battery. An ohm meter can check if the voice coil is open. But if it works hooked up to the radio, it is a harness issue
[Re: denfireguy]
#2158178
09/20/16 05:21 PM
09/20/16 05:21 PM
Posts: 282 Ashland City, Tennessee
Aar1064
Ok I thought of another thing I could do to test if it was the radio. I moved all the sound to left front again via fader and balance then directly connected speaker to radio and it works so it's not the radio.
Am I missing something? Could it be the crossover box?
[Re: Aar1064]
#2158665
09/21/16 12:01 PM
09/21/16 12:01 PM
denfireguy
Colorado
Could be the crossover box. Not much to them, just resistors, coils and capacitors that split the audio into higher frequencies for the two outside front speakers. The rear and center speakers get the full spectrum of audio. The capacitors I believe are non polarized electrolytics that are hard to find. Resistors and coils are easy to check with an ohmeter and seldom fail without obvious burn marks. Capacitors will show lower ohms when touched with meter probes and then go higher as it charges up. Reverse the leads and it will do the same again.
[Re: Aar1064]
#2159364
09/22/16 01:03 PM
09/22/16 01:03 PM
denfireguy
Colorado
Yes they are, and a crack is not a good thing. The electrolyte is all gone. That is an electrolytic capacitor. You will need one of the same or similar value with a voltage of around 25 volts or more. Craig
[Re: denfireguy]
#2159391
09/22/16 01:27 PM
09/22/16 01:27 PM
denfireguy
Colorado
40uf is an odd value. Next standard value is 47 uf http://www.mcmelectronics.com/product/31-8540or tie two of these in parallel: http://www.mcmelectronics.com/product/138-222213838229or see if you can find another crossover box. Craig
[Re: Aar1064]
#2160933
09/24/16 04:15 PM
09/24/16 04:15 PM
denfireguy
Colorado
You can bypass the crossovers with alligator clip leads. Only do it briefly and without much volume. The small speakers are not rated for the power to pass bass response. Full volume would probably get rid of your new voice coils. If there is sound out of the speakers, it proves that part of the crossover is bad. A multimeter probably is not a good indicator for voltage. An audio AC voltmeter would. DIY speaker dealers such as MCM carry crossovers for building home speaker systems. a two way crossover that sends bass to the center speaker and treble to the outside speakers would work. The crossover would be marked woofer (bass) and tweeter (treble). Craig
[Re: denfireguy]
#2161874
09/26/16 10:48 AM
09/26/16 10:48 AM
Aar1064
You can bypass the crossovers with alligator clip leads. Only do it briefly and without much volume. The small speakers are not rated for the power to pass bass response. Full volume would probably get rid of your new voice coils. If there is sound out of the speakers, it proves that part of the crossover is bad. A multimeter probably is not a good indicator for voltage. An audio AC voltmeter would. DIY speaker dealers such as MCM carry crossovers for building home speaker systems. a two way crossover that sends bass to the center speaker and treble to the outside speakers would work. The crossover would be marked woofer (bass) and tweeter (treble). Craig After trying the borrowed crossover didn't change anything, I jumped over the capacitor like you suggested, turned radio on and I have sound from the speaker. So I guess the same capacitor is bad in the borrowed crossover. That's my luck. Lol. Now we're getting somewhere. I'd like to keep original crossover box and replace the capacitors. Question is which will work? I'm confident in my soldering abilities but not so much in determining exactly what is needed. Thanks for the help
[Re: Aar1064]
#2161883
09/26/16 11:09 AM
09/26/16 11:09 AM
denfireguy
Colorado
I am confused on the non polarized capacitor. While most crossover capacitors are non polarized, the one in the picture is clearly marked with a positive terminal. Non polarized capacitors are not marked that way because they are by definition non polarized. Maybe it was replaced at some time and should have been non polarized. To answer your other question, yes 100V is just fine. That is the working voltage and it just has to be higher or equal to the replacement.
