E-Body Side Marker Lamp Lens/Housing Colors #2157254
09/19/16 10:19 AM
09/19/16 10:19 AM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I disassembled my front fender side marker lamps and noticed that the amber lenses installed are 2 different colors of amber (dark and lighter). Also, one housing appears to be painted flat black, while the other is natural plating. The darker amber lens was installed on the black housing. See pics below.
The “darker” lens matches the reflector more closely than the lighter lens.
Is one of these lenses/housings an “early” vs. “late” style, or were there just two different styles available during production…paint vs. unpainted? Any thoughts on what should be correct for my B21 SPD car?
Has anyone else seen this on their cars?
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157282
09/19/16 11:42 AM
09/19/16 11:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Several possibilities, 2 or more different vendors, same vendor and a superseded part supplied, worker on the left side of the line had his supply, worker on the right side of the line had his supply?, or it was replaced at some time by a repair shop/dealer?...keep in mind you can only look at one side of the car at a time smile
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157288
09/19/16 11:47 AM
09/19/16 11:47 AM
California
biggE Offline
biggE  Offline
California
When the car was restored years ago the builder had a collection of different parts to choose from including some nos parts.
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157298
09/19/16 12:02 PM
09/19/16 12:02 PM
Indianapolis, IN
Indianapolis, IN
That what I wondered. Wasn't sure if the black housing was an NOS replacement, meaning it's a later part vs. the natural housing...or vice-versa.
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157348
09/19/16 01:02 PM
09/19/16 01:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The plastics were from different batches and quality control was way off.
As biggE pointed out the builder had a collection of used and NOS parts at the time.
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157423
09/19/16 02:49 PM
09/19/16 02:49 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Rob,
Were one of the lenses installed upside down when on the car?
Also, can you make out the lettering on the inside of the lower one pictured compared to the upper?
Tom
68 Charger
70 Cuda
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157442
09/19/16 03:15 PM
09/19/16 03:15 PM
Indianapolis, IN
Indianapolis, IN
Hi Tom,
The passenger front amber lens and the driver's rear red lens were installed upside down, while the others were in the correct orientation.
This is because the lenses were not designed as a right and left fitment. There is only 1 lens PN for both sides, and one has to be installed upside down to fit in the reflector housing correctly.
Make sense?
I can make out the part numbers, and they are: 3403623-Amber and 3403639-Red. Both part numbers in the amber lenses are the same.
Rob
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157481
09/19/16 03:58 PM
09/19/16 03:58 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Yes, just making sure you were aware.... wave
68 Charger
70 Cuda
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: FC7cuda] #2157573
09/19/16 05:42 PM
09/19/16 05:42 PM
Indianapolis, IN
Indianapolis, IN
No worries! up
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157625
09/19/16 06:55 PM
09/19/16 06:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Just for fun, check the vendor codes to see if they differ. (five numbers in vendor codes)
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2157809
09/19/16 11:12 PM
09/19/16 11:12 PM
Indianapolis, IN
Indianapolis, IN
Barry,
I just checked and the vendor code is the same for both the housings and the lenses for both types. The vendor code is 46050.
Rob
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2158180
09/20/16 05:22 PM
09/20/16 05:22 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I see remnants of black paint in the letters on the bare bezel. Anyone I've ever seen on the front of original cars were black.
Re: E-Body Side Marker Lamp Lens/Housing Colors [Re: B5Cuda440-6] #2158602
09/21/16 09:57 AM
09/21/16 09:57 AM
Indianapolis, IN
Indianapolis, IN
Thanks, Mike. That's what prompted my first post. Was trying to determine if original cars had black painted housings in the front, or bare.
Rob
