Are 360 Magnums a good Street/Strip choice ? #2157198
09/19/16 01:59 AM
09/19/16 01:59 AM
mld94
mld94
Just wondering what the pros and cons are of the 360 Magnum engines, compared to the LA 340 and 360s.
I have access to a relatively low mileage good running 360 out of a 2001 Dodge Ram.
Are these blocks considered strong enough for 500+hp or turbo applications ?
Re: Are 360 Magnums a good Street/Strip choice ? [Re: ] #2157200
09/19/16 02:01 AM
09/19/16 02:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Plenty good enough and you can go with a roller cam
for cheap
wave
Re: Are 360 Magnums a good Street/Strip choice ? [Re: ] #2157234
09/19/16 08:00 AM
09/19/16 08:00 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
There are several people running well north of 700 hp with turbo/sc/nitrous.
Re: Are 360 Magnums a good Street/Strip choice ? [Re: ] #2158015
09/20/16 11:34 AM
09/20/16 11:34 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I love Magnums. Not only for improved oil sealing at the pan and valve covers, but because swapping older Mopars over to EFI is virtually plug and play.
I have since built a 408" stroker version that puts out something like 500+hp.
Re: Are 360 Magnums a good Street/Strip choice ? [Re: ] #2158030
09/20/16 11:50 AM
09/20/16 11:50 AM
Houston, Texas
Houston, Texas
Check out the lated vid of SlammedR/T running his stroker Magnum with nitrous.
