New Victor head small block headers
#2157137
09/19/16 12:16 AM
09/19/16 12:16 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Just looking on TTI's site and see these are now available. 1 7/8 to 2 inch step. Look nice.... And pricy. Cool pictures they have with a W5 and the Victor head side by side so you can see the .530 difference in height. Wish I had a nice x block laying around.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: New Victor head small block headers
[Re: B3422W5]
#2157143
09/19/16 12:26 AM
09/19/16 12:26 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: B3422W5]
#2157300
09/19/16 12:02 PM
09/19/16 12:02 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Look nice, what's the price point?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: RAY1969CARS]
#2157336
09/19/16 12:47 PM
09/19/16 12:47 PM
B3422W5
Portage,michigan
The headman hustler W-2 and hooker super com adjustables are a far way better header then that TTI junk in my opinion Maybe, maybe not. But as made, they won't fit. The victors have a raised port
[Re: RAY1969CARS]
#2157338
09/19/16 12:49 PM
09/19/16 12:49 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
The headman hustler W-2 and hooker super com adjustables are a far way better header then that TTI junk in my opinion Do you have a part number for the Headman header that works on the Victor Head?
68 Barracuda Formula S 340
[Re: Bad340fish]
#2157339
09/19/16 12:51 PM
09/19/16 12:51 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
No but you have adapter plates made up and just port match here are several plates that I did for My w5s with supercom adjustable headers hooker
[Re: B3422W5]
#2157345
09/19/16 12:59 PM
09/19/16 12:59 PM
B3422W5
Portage,michigan
If you go to the TTI website and find the headers, they have a little W5/ Victor footnote that shows several pictures of those heads side by side. The Victor is over 1/2 inch taller..
Personally I wouldn't discount the performance of the TTI's . My old W5 motor has been 140 mph at 3220 pounds with those headers on it N/A on super stock springs. And those don't step to 2 inches like these new Victor headers, nor are they 3.5 inch collectors like these are.
[Re: RAY1969CARS]
#2157391
09/19/16 02:03 PM
09/19/16 02:03 PM
Posts: 1,073 oregon
greendart408
oregon
The headman hustler W-2 and hooker super com adjustables are a far way better header then that TTI junk in my opinion Agreed, been there done that. Hedmans were over a tenth faster and 1.5mph better than tti's on my w5 stuff. These are a better design tho I see. Went 9.55@139.99 with hedmans, tti's 9.72@138, bests for each. Both were 1 7/8s, I custom built from pipemax a set myself, went zero faster than the hedmans. Was just my findings on MY stuff.
[Re: B3422W5]
#2157583
09/19/16 06:00 PM
09/19/16 06:00 PM
1967dartgt
Hilltown Pa
Wow, no brainer I would just go custom.
[Re: 1967dartgt]
#2157596
09/19/16 06:17 PM
09/19/16 06:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wow, no brainer I would just go custom. Thats the thing with a shelf header.. they are NOT right for ALL engines.. they pick the most common set up and build for that.. most arent even equal length or even close for any one engine... but they fit... I'm not a fan of TTI headers but they fit
[Re: 1967dartgt]
#2157611
09/19/16 06:42 PM
09/19/16 06:42 PM
Posts: 3,395 Pa
Hot 340
Pa
Wow, no brainer I would just go custom. Custom isnt always an easy solution either. Dragging a car all over, waiting for "your turn", price not as quoted, workmanship not always as expected, timeline not as expected, ect ect ect.
[Re: Hot 340]
#2157704
09/19/16 08:48 PM
09/19/16 08:48 PM
MR_P_BODY
Is this small block Victor head designed for a 48* or a 59* block.. I see the bottom row of bolt holes on them.. I'm looking for some new heads.. but all I seen on them doesnt say which block
[Re: Hot 340]
#2157725
09/19/16 09:19 PM
09/19/16 09:19 PM
1967dartgt
Hilltown Pa
Wow, no brainer I would just go custom. Custom isnt always an easy solution either. Dragging a car all over, waiting for "your turn", price not as quoted, workmanship not always as expected, timeline not as expected, ect ect ect. Got a good header guy, always what he quotes and does them in a week or two. He has done the last two sets of mine and a half dozen of my buddies that I sent there. He also does them for the same price as those TTI's.
[Re: 1967dartgt]
#2157728
09/19/16 09:22 PM
09/19/16 09:22 PM
B3422W5
Portage,michigan
Wow, no brainer I would just go custom. Custom isnt always an easy solution either. Dragging a car all over, waiting for "your turn", price not as quoted, workmanship not always as expected, timeline not as expected, ect ect ect. Got a good header guy, always what he quotes and does them in a week or two. He has done the last two sets of mine and a half dozen of my buddies that I sent there. He also does them for the same price as those TTI's. Where is the guy located Brad
[Re: MR_P_BODY]
#2157729
09/19/16 09:22 PM
09/19/16 09:22 PM
1967dartgt
Hilltown Pa
Is this small block Victor head designed for a 48* or a 59* block.. I see the bottom row of bolt holes on them.. I'm looking for some new heads.. but all I seen on them doesnt say which block Work on both blocks, but you can't use the top row of bolts on R blocks. They screw in the head from the bottom and you can't drill threw the head there they made the oil drain backs there.
