Reproduction mopar heater hoses #2156049
09/17/16 02:02 AM
09/17/16 02:02 AM
Dayton, WA
wesgtx440 Offline OP
Dayton, WA
Are all the reproductions available from the various vendors made by the same company? are they all super thick wall hose? reason I ask is I'm trying to install mine and am having great difficulty not peeling the inner layer away and cannot get them to slid on to the fittings. Any tips or trick to install these damn things? Car is 68 Charger, 440.
Thanks for any help.
68 Charger R/T 440 auto
Re: Reproduction mopar heater hoses [Re: wesgtx440] #2156118
09/17/16 09:14 AM
09/17/16 09:14 AM
PA
70Duster Offline
70Duster  Offline
PA
A little lubrication (ie: light oil, petroleum jelly, or white grease) on the end of the hose and the fitting will allow them to slide right on. And, no these lubricants will not harm the hose.
Re: Reproduction mopar heater hoses [Re: 70Duster] #2156171
09/17/16 11:46 AM
09/17/16 11:46 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
What he said
Re: Reproduction mopar heater hoses [Re: wesgtx440] #2156192
09/17/16 12:37 PM
09/17/16 12:37 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
If you're concerned, antifreeze lubricates, too.
Re: Reproduction mopar heater hoses [Re: wesgtx440] #2156226
09/17/16 01:37 PM
09/17/16 01:37 PM
WA
tman Online content
tman  Online Content
WA
Silicone spray
Re: Reproduction mopar heater hoses [Re: wesgtx440] #2156838
09/18/16 02:53 PM
09/18/16 02:53 PM
Dayton, WA
Dayton, WA
Thanks all for the replies. I ended up using white lithium grease. I was able to get them slid on the outlets for the heater core. Connecting them to the water valve for the a/c still proved to be a major challenge. Finally was able to get it though.
Re: Reproduction mopar heater hoses [Re: wesgtx440] #2157205
09/19/16 02:26 AM
09/19/16 02:26 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Dats what I use. You certainly would have a start of a very bad day if you were to break off the heater tubes that the hoses attach to by forcing then on.
