Help with LM1 #2156360
09/17/16 06:20 PM
09/17/16 06:20 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Mine only reads this
Re: Help with LM1 [Re: Scamp408] #2156373
09/17/16 06:59 PM
09/17/16 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a LM1 but the only thing I seen out of normal
was ERROR which ended up being a broken wire in the
extension wire.. I couldnt get it to work and sent it
back and they found the issue.. cost me the price of
the extension wire.. since then its been fine... sorry
I cant help with your issue.. might want to call the
company and see what they say... there use to be a good
Q and A on their website.. not sure if its still there
wave
Re: Help with LM1 [Re: Scamp408] #2156658
09/18/16 07:27 AM
09/18/16 07:27 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I guess I will have to. Its weird one day it started to just read lamda no %
Re: Help with LM1 [Re: Scamp408] #2156730
09/18/16 11:44 AM
09/18/16 11:44 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
plug it in to your computer. run the lm programmer software, and you can select what you want it to read.
Re: Help with LM1 [Re: Scamp408] #2157072
09/18/16 10:47 PM
09/18/16 10:47 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I will give it a try
Re: Help with LM1 [Re: Scamp408] #2158610
09/21/16 10:13 AM
09/21/16 10:13 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Is this what I'm looking for
Re: Help with LM1 [Re: Scamp408] #2158662
09/21/16 11:58 AM
09/21/16 11:58 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yes. Click on the "use air-fuel ratio"
Re: Help with LM1 [Re: Scamp408] #2158677
09/21/16 12:21 PM
09/21/16 12:21 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I did it on both channels. After I went to ck it so I unplugged and tried again it reverted to lambda so I hit a/r again. Weird how it went to lambda
Re: Help with LM1 [Re: Scamp408] #2158679
09/21/16 12:26 PM
09/21/16 12:26 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I reset to a/r and shut it down. I hooked it back up and got this.
Re: Help with LM1 [Re: Scamp408] #2158968
09/21/16 08:06 PM
09/21/16 08:06 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
We are all fixed thanks for the help guys. Now wait for my post with my miss at 2000 problem
