440-6/Hemi Prestolite dual point distributor contact points #2156205
09/17/16 12:53 PM
09/17/16 12:53 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Hey guys, for anyone who hasn't converted to electronic ignition yet - I need help finding a replacement point set. What are you using and where are you buying? My distributor number is #IBS-4014A 42 8 Thanks
Re: 440-6/Hemi Prestolite dual point distributor contact points [Re: pacifica] #2156260
09/17/16 02:30 PM
09/17/16 02:30 PM
get ahold of "Joesixpack" on here. I'm sure he has (at least) a dozen sets in his bedroom dresser (top) drawer. He's a good guy to deal with too
Re: 440-6/Hemi Prestolite dual point distributor contact points [Re: pacifica] #2156442
09/17/16 09:09 PM
09/17/16 09:09 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I did a DP dist.for a 66 383 Hipo.and used all Standard motor products Blue Streak parts from rockauto.
Re: 440-6/Hemi Prestolite dual point distributor contact points [Re: 71GTX471] #2156450
09/17/16 09:20 PM
09/17/16 09:20 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
will check stock and let you know found some accels on ebay and sent you the link those are for the prestolite mopar dual point and good to 7000 rpm
