66/67 Coronet and Satellite doors #2156024
09/17/16 12:45 AM
09/17/16 12:45 AM
Saskatchewan, Canada
barracudabob Offline OP
I heard somewhere that 1966 and 1967 Coronet and Satellite/Belvedere doors will physically interchange, and other than trim holes, are identical. This is for a two door hardtop. Is this true?
Re: 66/67 Coronet and Satellite doors [Re: barracudabob] #2156050
09/17/16 02:05 AM
09/17/16 02:05 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Yes
Re: 66/67 Coronet and Satellite doors [Re: barracudabob] #2157943
09/20/16 03:35 AM
09/20/16 03:35 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes the complete unit will swap between cars.
But, the glass and top rubber piece on the wing frame is different. So if you try to mix and match they will not fit. The glass is cut for that piece and the cut is different 66 and 67. If you look at some you will see the difference.
