brake issue #2156009
09/17/16 12:05 AM
09/17/16 12:05 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Had a local Mopar guy meet me this morning to show me an issue he was having with the drum brakes on his 70 GTX. It is a power drum car with 11" drums. I drove the car and it is scary! When you apply the brakes the brakes @ about 1/4 of a pedal they will grab and about throw you through the windshield. He has changed the brake lines, hoses, wheel cylinders, distribution block, master cylinder, booster, shoes and had the drums turned. Feels to me to be a friction issue with glazed shoes or overheated drums. Anybody ever experience this or have any suggestions?
Re: brake issue [Re: GKMOPAR] #2156013
09/17/16 12:10 AM
09/17/16 12:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By GKMOPAR
Had a local Mopar guy meet me this morning to show me an issue he was having with the drum brakes on his 70 GTX. It is a manual drum car with 11" drums. I drove the car and it is scary! When you apply the brakes the brakes @ about 1/4 of a pedal they will grab and about throw you through the windshield. He has changed the brake lines, hoses, wheel cylinders, distribution block, master cylinder, booster, shoes and had the drums turned. Feels to me to be a friction issue with glazed shoes or overheated drums. Anybody ever experience this or have any suggestions?
Sounds like he has the shoes mixed up?
Re: brake issue [Re: GKMOPAR] #2156032
09/17/16 01:10 AM
09/17/16 01:10 AM
check pushrod rounded nub clearance (want ~.020") then do a visual on the linings: take the drums off & have a helper CAREFULLY SLOWLY press the pedal then jab the pedal (barely) to see if there is any hanging up on the shoes & you see if there is anything not right/hanging up (I think you are OK there) just be carefull to not let him move the wheel cyl cups too far. if all good so far then it about has to be a booster/check valve issue (did he reuse the same check valve?) EDIT my bet is a booster/check valve/pushrod clearance issue, one of them
Re: brake issue [Re: GKMOPAR] #2156047
09/17/16 01:52 AM
09/17/16 01:52 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I did ask about primary and secondary shoe. He told me he had the longer shoe on the rear which I believe is correct. Looks like the check valve has been replaced. Sounds like the previous owner had the same issue. He also told me when he bought the car the left front drum got so hot it locked up and was smoking. That was before replacing all the parts that he has. He has thrown about every replacement part at it trying to fix the issue. The only thing not replaced were the drums and they were turned. He adjusted the brakes kind of loose to make it somewhat drivable.
Re: brake issue [Re: GKMOPAR] #2156053
09/17/16 02:28 AM
09/17/16 02:28 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Brake booster out of adjustment?
Re: brake issue [Re: GKMOPAR] #2156119
09/17/16 09:19 AM
09/17/16 09:19 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Sounds like a pedal or master problem...your saying its applying full pressure on only 1/4 pedal travel to lock it up..
Re: brake issue [Re: GKMOPAR] #2156125
09/17/16 09:32 AM
09/17/16 09:32 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
He said it was as soon as you hit the pedal and the only reason it is @ 1/4 pedal now is because he backed off the brake adjustment to make it somewhat drivable. What booster should this car have? The one on my 69 GTX is the larger bendix unit but I have disc on my car.
Re: brake issue [Re: GKMOPAR] #2156169
09/17/16 11:41 AM
09/17/16 11:41 AM
Andrewh Offline
Andrewh  Offline
in the op it says manual drum car. not power drum.
If it is power drum, there is an internal valve that failes some times.
It is supposed to gradually open, but can sometimes stick and then fully open. If tht happens you get a sudden burst of assist.
I have had one that did that and replaced it.
Re: brake issue [Re: GKMOPAR] #2156294
09/17/16 03:51 PM
09/17/16 03:51 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Sorry it is power drum. Said he had booster rebuilt but it was the one on the car when he bought it. I believe he said he replaced the check valve too. The pedal is easy to push throughout its travel. The reason I asked about the correct boosters is I don't know if the pivot linkage that is attached to the pedal is the same for both.
Re: brake issue [Re: GKMOPAR] #2156313
09/17/16 04:19 PM
09/17/16 04:19 PM
Andrewh Offline
Andrewh  Offline
it isn't the check valve. that just holds vacuum inside the booster.
there is an internal valve that allows vacuum to pass to start the assist.
that valve for lack of a better word gets sticky. It will hold shut then instantly pop open allowing more assist than anticipated.
you can narrow it down to the booster by removing the vacuum assit and you can see if it still does it.
plug the vacuum line to the booster and pump it till the pedal is hard.
then try it and see if you still have an issue.
Re: brake issue [Re: GKMOPAR] #2156603
09/18/16 02:00 AM
09/18/16 02:00 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I will pass that on. That will at least eliminate a vacuum issue with the booster.
Re: brake issue [Re: GKMOPAR] #2156800
09/18/16 01:34 PM
09/18/16 01:34 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
so the car had this problem before all the parts were changed out..some cars has 2 spots to hook up the rod on the brake pedal...then some have a z linkage also..I would try to compare to another same car
Re: brake issue [Re: GKMOPAR] #2157112
09/18/16 11:44 PM
09/18/16 11:44 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I did look @ the brake pedal and there is a z linkage. It was that way when he got it but not sure if it is correct. My 69 GTX has a z linkage and a Bendix booster but has disc brakes. His is a 70 and has a z linkage and a different booster but has 4 wheel drum brakes. Does anyone have a 70 GTX, Charger or Coronet R/T with power drum brakes to compare to?
Re: brake issue [Re: GKMOPAR] #2157122
09/18/16 11:56 PM
09/18/16 11:56 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
have you tried it in reverse? do the brakes react the same? that would help eliminate brake shoe issues from the goose chase. twocents
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
