Andy's billet rear seal retainer #2154688
09/14/16 09:35 PM
09/14/16 09:35 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
The orange rear main seal that come with the billet retainer kit any good? Using a Molnar crank.dont want any leaks
Re: Andy's billet rear seal retainer [Re: mopar dave] #2155470
09/16/16 12:55 AM
09/16/16 12:55 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
That will really depend on you. The black and orange seals both work just fine. I will go as far to say that as long as the stock seal retainer is not damaged it works as well as any seal retainer. Pay attention to the alignment of the top and bottom seal by lining them up without the crank in. Once you have them perfect, scribe a reference line across the bottom of the seal retainer and block. Now when you install the crank you know what position to torque the retainer because there is some play that can cock the seal if no reference line is scribed. Remember, Mopars had rope seals back in the day so a little play did not matter. In other words, if it leakes it's on you...
Re: Andy's billet rear seal retainer [Re: ccdave] #2155506
09/16/16 02:00 AM
09/16/16 02:00 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks for the info on that. been reading the other post about this. Monty says to turn the seal 90* to the block/cap parting line. sounds reasonable, but haven't heard anyone doing this but him.
