Re: i avoided a 727 explosion ,,,,, [Re: SpareParts] #2155651
09/16/16 12:21 PM
09/16/16 12:21 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By SpareParts
Originally Posted By DrCharles
Could have gone A833 instead, and never have to worry about sprags again devil
Until the gears lock up on the shaft and the trans locks and your car skids through the traps and possibly into the wall.... yup replacing a car is way cooler than replacing a sprag
Sorry that happened to you! What was the root cause? I've never seen a failure like that...
Edit: also, I'm sure the dozens of little planetary gears in an automatic couldn't possibly bind or lock up... could they? work
Re: i avoided a 727 explosion ,,,,, [Re: pittsburghracer] #2155806
09/16/16 04:14 PM
09/16/16 04:14 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
Originally Posted By pittsburghracer
Mmmmmmmmm, LOVE my powerglide. LOL
Yep. That's what's in mine now. Along with a dana 60.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155878
09/16/16 06:32 PM
09/16/16 06:32 PM
A727Tflite Offline
A727Tflite  Offline
Stock bolt in ORC are not a waste of time - without the bolt in ORC you would have failed more than what you did - you just exceeded the capacity of the case by having a bolt in ORC. It did it's job and may have saved your feet.
At Chrysler back in the 80's - NYPD and Detroit PD used to regularly fail the transmissions when the cops did "certain" maneuvers on the 727 cop cars, on the El Cheapo police package with 998 - we never had any ORC failures. Same findings up to when we stopped making the 42/44RE versus the same basic truck with a 46. More ORC elements (rollers) reduces the opportunity for roller tilting from "spit back".
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2156010
09/17/16 12:05 AM
09/17/16 12:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Here is mine:
Re: i avoided a 727 explosion ,,,,, [Re: 451Mopar] #2156148
09/17/16 10:42 AM
09/17/16 10:42 AM
moparx Offline
moparx  Offline
some where in the recesses of my feeble mind, i recall something about using an ORC from a C-6 ford ? something about having twice the rollers and springs, or am i delusional from all my meds ? does anyone else remember this ?
beer
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2156284
09/17/16 03:37 PM
09/17/16 03:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Originally Posted By hp340nos
i broke 8 teeth on my 8 3/4 last friday at dragstrip on launch.decided to pull the tranny and check the sprag,sure enough it cracked the case in 2 spots and collapsed the wave springs,it was a bolt in stock style sprag.valvebody is a reverse pattern low band apply style.
that's really hard to believe eyesglad you did the right thing.
Re: i avoided a 727 explosion ,,,,, [Re: Quicktree] #2156329
09/17/16 05:09 PM
09/17/16 05:09 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
yes it banged hard, when the teeth broke, it happened on launch.glad there and not at top end of the track
