340 connecting rods - what's the scoop? #2154431
09/14/16 03:33 PM
09/14/16 03:33 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
2406785 = part number ('59-'71 318 "A"/"LA" & '64-'69 273 "LA")
floating pin
* 1618699 = forging number
* 2406872 = forging number
2899495 = part number ('68-'73 340 "LA" & '72-early'73 318 "LA")
floating pin
* 2899496 = forging number
2899061 = part number (late'73-'80 360 "LA" & late'73-'80 318 "LA")
pressed pin
* 3418645 = forging number
I also found reference to this part number, but it overlaps the above info?:
3751015 = part number ('71-'76 360 "LA" & late'73-'76 318 "LA")
so, if I WANT to build an authentic 1970 340 engine with "correct" vintage rebuilt/remanufactured/restored parts/components - the 2899495/2899496 rod is the ONLY correct rod?
I understand there are cheaper/newer/stronger modern rods - but I WANT a 1970 340 engine realcrazy
some charts show a .100" "offset" on the 340 floating rods, what/where is this dimension?
Re: 340 connecting rods - what's the scoop? [Re: 6bblgt] #2154459
09/14/16 04:04 PM
09/14/16 04:04 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Want to go really nuts? When we had to use OE rods in our Super Stock 340's way back when there were different foundries producing floating rods. I can not for the life on me remember the markings, same casting numbers though, but these were lighter than the ones from the other manufacturer. I think it was 15 or 20 grams lighter.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 340 connecting rods - what's the scoop? [Re: 6bblgt] #2154969
09/15/16 10:04 AM
09/15/16 10:04 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
2899496 = forging number This rod can be in a press pin fit or floating pin configuration. Only difference is a bushing in the small end. The 340s used the floating pin style rod.
The 0.100" offset is in the piston, not the rod. This offset was to reduce piston slap (rattle) when the engine was cold. Old trick was to swap pistons from one bank to the other to reduce friction drag for racing.
The early 318 rods were lighter but had a floating pin. 318 rods were 726 grams vs the 340 at 758 grams.
So, the '70 340 would use the 2899496 rod with bushed small end for floating pin.
