1969 Ignition Switch Removal #2154121
09/14/16 12:11 AM
09/14/16 12:11 AM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
How do you get the ignition switch out of the dash on a 69 Dart? I have the key... I need to remove the switch to get the original key number off the switch
Re: 1969 Ignition Switch Removal [Re: JRepucci] #2154137
09/14/16 12:36 AM
09/14/16 12:36 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
At least on B body, it's like that nut that holds the antenna on. It needs to be turned a bunch. You can do it with a screwdriver and may need something to tap on the screwdriver- just know if may mess up that nut.
A member makes a tool to remove them also (PN: mopar 002) it's on the second page: http://www.custommachinecomponents.com/shopdisplayproducts.asp?id=8&cat=Mopar
Re: 1969 Ignition Switch Removal [Re: JRepucci] #2154152
09/14/16 12:54 AM
09/14/16 12:54 AM
JRepucci Offline OP
JRepucci  Offline OP
Re: 1969 Ignition Switch Removal [Re: JRepucci] #2154827
09/15/16 12:09 AM
09/15/16 12:09 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Once you pull the ignition switch assembly out of the dash from behind, you have to take the switch out of the housing. There is a spring loaded pin in the side of the housing. You have to put the key in the switch and turn it in order to push the pin in from the side and pull the switch out
