ignition feed back
#2153032
09/12/16 01:00 PM
09/12/16 01:00 PM
Posts: 7,506 Az
Crizila
Az
Seems to be intermittent, but there are times when my engine will keep running after I turn the ignition off. No, it's not a pre-ignition ( dieseling ) problem. The ignition is getting power from somewhere other than the ign. switch. Any ideas? I'm think ether my 1 wire alternator or possibly my electric fan motor. Haven't done any trouble shooting yet. If I can get it to do it, I will start pulling fuses. Thanks, John
Fastest 300
Re: ignition feed back
[Re: moparx]
#2154069
09/13/16 11:12 PM
09/13/16 11:12 PM
Posts: 7,506 Az
Crizila
Az
wasn't sure you had the dash mounted switch you have, or a column switch. i have seen the column switches of various brands melt around the connections and at the switch spades leading to just the symptoms you describe. i can't tell from the pic i have of that switch [in the speedway catalog], but is the connector a push on, or does each wire have a screw attached terminal ? Wires coming off the back of the switch are actually "potted" - no wire connections on the back of the switch.
Fastest 300
