Air pressure slicks
#2153285
09/12/16 08:48 PM
09/12/16 08:48 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
Giving up on the M/T drag radials after years of trying, when the tracks were well prepped good traction, when not no traction. Just bought 28x10.5x 15 stiff sidewall bias ply. Car weights 3650 lbs, 650 hp, caltracs, trans brake.
Where should I start with air pressure? I was thinking around 9 lbs.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Air pressure slicks
[Re: caper]
#2153312
09/12/16 09:39 PM
09/12/16 09:39 PM
Thumperdart
State of confusion
I started at 12 but killed the tire so 13 next time for me............went 1.33 like that.........
[Re: caper]
#2153320
09/12/16 09:50 PM
09/12/16 09:50 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Not all tire gauges read the exact same pressures, start high and look at the tire wear pattern and the time slip while going down 1/4 to 1/2 lbs at a time on the pressures to get the best results in your 60 ft times Are you running tubes and what width rims are those tires on? What RPM do you leave at? On your deal I would start at 14 or 15 lbs and go from there If it dead hooks at that pressure go up 1 lb. at a time until it spins and then come back down to the best 60 ft. times The last pair of 9x30x15 bias ply slicks I ran on my old M.W. stocker over 20 yrs ago had 18 lbs in them, they where mounted on 10 inch wide wheels and we where eleaving from 2700 to 3500 RPM foot braking, 1.42 60 ft times That was long before the drag radial tires where introduced
[Re: caper]
#2153339
09/12/16 10:27 PM
09/12/16 10:27 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I tried my new M/T 315/60 Radial Pros last weekend and on the 2nd pass I broke a axle with 18 lbs of air with home made Caltracs and stock leaf springs. I will never run a slick again. This was on a Test & Tune night and track prep is not a priority. Had a 1.35 60 ft. on first pass.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: caper]
#2153552
09/13/16 10:06 AM
09/13/16 10:06 AM
caper
No tubes. I have 8" rims, I know M/T says min 9' but it is what it is. I was leaving at 2700 rpm, will try to leave higher if they hold. My best 60' with radials was 1.41. I will start at 15 lbs see what happens. Thanks for your replys.
[Re: caper]
#2153795
09/13/16 04:33 PM
09/13/16 04:33 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
All cars and combos are different. Use what works bets in YOUR car. FWIW my Valiant ran 10.25 generally and went 9.0 at 150. The heads up car uses a 29.5x10.5SS tire and we are anywhere from 9.25-9.75 depending on the track conditions.
[Re: caper]
#2153977
09/13/16 09:06 PM
09/13/16 09:06 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Does it actually go that high? Or higher? Sometimes leaving at a lower rpm winds the converter up like a rubber band and it's too much for the tire initially. Not giving the converter enough room to do that sometimes will help. I went 1.22 60' leaving at 4,000. 6,100 stall converter. My car will react quicker at a higher rpm but usually those 60's are 1.24- 1.28. To be honest, I haven't tested the wide open program in the last couple of years. I'm always on the t/stop. With your kind of hp and tq, it seems like you should need wheelie bars. 90-10 shocks on the front?
[Re: caper]
#2153981
09/13/16 09:11 PM
09/13/16 09:11 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
that car is too heavy for anything less than 12lbs.. by the way .2 lb changes are a big change in a slick . so when you get close i would only go in 1/2 a pound increment changes.. then 2/10ths after that... something else you can do is a hole shot on concrete and then look at the patch pattern left on the concrete. if you see dark lines on the outside edges of the skid mark .. then you need more air..fwiw. Too low air pressure in a car as fast as your will be all over the place at high speed/down track. and a hand full
my experience is to be down around the 10psi range the cars are 3000lbs or less. imho
fwiw. my car weighs 3310lbs if i go below 11.2 lbs ..i know it cause the car wanders down track . Duster 28x10.5 x 15 M/T slick
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: caper]
#2154173
09/14/16 01:26 AM
09/14/16 01:26 AM
caper
Not sure what RPM I left at when it had a 1.41 60 ft. Peak tq at 4400 rpm, peak HP at 5600 rpm. I shift at 5600 rpm. I tried shifting at 6200 rpm, car slowed down. PTC convertor. Weighed car 49% on front, 51% back. Front end not very loose when trying to lift it. Only have about 4" travel front end Alterkation front end. Lifts front wheels about 2".
