Help Identifying rear end in 33 Dodge!?!? #2152453
09/11/16 05:14 PM
09/11/16 05:14 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Hi,
Hopefully I'm posting in the correct section here. I have a 1933 Dodge DP that was my grandfathers and has been sitting since he passed away in 2000. I have been doing a lot of work to it but my new project is the brakes. And I have no Idea what the rear is from, My dad said it possibly came from a rambler? Would anyone be able to identify this by the pic? It has a tag with 3.54 gears. And a stamp with saying US PAT. 2018188 Its similar in size to a Mopar 7 1/4" I'm hoping to identify this so I can get wheel cylinders and brakes.. Any help is appreciated!
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2152480
09/11/16 06:25 PM
09/11/16 06:25 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
I believe it may be a dana 30. 1966-83 jeep cj5 and cj6
Re: Help Identifying rear end in 33 Dodge!?!? [Re: 5280Dart] #2152941
09/12/16 09:29 AM
09/12/16 09:29 AM
moparx Online content
moparx  Online Content
it looks like you are using a hub puller for the drums in the second pic. ramblers used those type axles, i believe, almost until the demise of american motors. if it has a sure grip type rear, and it is a rambler, there could be a tag on it saying "twin traction". i can't offer any ideas about what the rear may be, or the application, but you may be able to get an idea by measuring the drum, brake shoes, and see if there are any numbers on the wheel cylinders. grampa had a very nice car. glad you are getting it back in circulation. if worse comes to worse, you could always just swap out the rear to something with more desirable [and easier to work on] flanged axles. if you find out what that rear is, let us know please. just curious. if it were a jeep axle, in the 66 up year range, i think it would be a 5 on 5 1/2" bolt pattern with a very large hub register [to clear the front locking hubs] which would require adapters to run your original wheels. ramblers were a 5 on 4 1/2" bolt pattern with a 2.790-2.800 [or so] hub register, same as your wheels should be.
beer
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2153379
09/12/16 11:10 PM
09/12/16 11:10 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Thanks for the responses! I started by looking up the Dana 30 for a jeep and started finding lots of pics that looked like the correct center. And I cross referenced that and found several things it could have come from like a jeep, rambler, Studebaker and a few others. It has 9" brakes, I haven't taken the drums off yet. It is an open rear for sure not sure grip. The spring perches are 42.5" center to center, look to be in original spot. Once I get the drums off I can measure the piston of the old wheel cylinders. Saw several different sizes listed for that size rear..
1933 Dodge DP (201)
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2153819
09/13/16 05:06 PM
09/13/16 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most Dana rear ends will have a BOM number stamped in the right tube (see red oval below) which will ID it. Scrape off the rust/crud and look for the number.
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2154013
09/13/16 10:03 PM
09/13/16 10:03 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
A body 8.25?
Re: Help Identifying rear end in 33 Dodge!?!? [Re: savoy64] #2154259
09/14/16 09:54 AM
09/14/16 09:54 AM
Originally Posted By savoy64
A body 8.25?
the 8 1/4 does not have the keyed axles that require a puller to remove the drum/hub assembly. the special puller required is shown under the assembly in the second picture.
beer
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2199150
11/19/16 10:29 PM
11/19/16 10:29 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Delayed thanks for everyones input. Been working on lots of projects... I ordered wheel cylinders for a 1958 American ramber and they fit perfect. Its a 7 3/4" gear. Also cleaned up the rear, gasket was leaking badly! And was able to wash it off and take some pictures! Still need a cylinder head for it that isn't cracked!
1933 Dodge DP (201)
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2203182
11/27/16 03:21 AM
11/27/16 03:21 AM
British Columbia, Canada
cocobolo Offline
cocobolo  Offline
What a gorgeous car! Glad you had success with the rear end.
Re: Help Identifying rear end in 33 Dodge!?!? [Re: cocobolo] #2206575
12/02/16 06:23 PM
12/02/16 06:23 PM
dogdays Offline
dogdays  Offline
That basic flathead six remained in production until 1959 in cars. You may find help, there are clubs that do pretty extensive gathering of reproductions. For example, https://www.chryslerclub.org/reproduction.html. Then there is the Plymouth Owners Club, you definitely want to belong to it. Started out as the Plymouth 4 and 6 cylinder Owners Club. Here's the application for membership.
http://clubs.hemmings.com/plymouthowners/2006-images/application.pdf
There is an aluminum higher compression head that was optional on your engine, the Red Head.
R.
Re: Help Identifying rear end in 33 Dodge!?!? [Re: dogdays] #2206889
12/03/16 11:59 AM
12/03/16 11:59 AM
i have seen a couple of "red" heads over the years [no, not that kind apimp], but i always thought those were an aftermarket item. optional you say ? what other items , if any, were included with those heads ?
beer
Re: Help Identifying rear end in 33 Dodge!?!? [Re: moparx] #2208927
12/06/16 08:30 PM
12/06/16 08:30 PM
dogdays Offline
dogdays  Offline
I only ran across the subject when looking into the engine and what head might work. This engine was in production in some way shape or form until at least 1959 and probably into the '70s. I know my friend put a 1959 engine in a 1948 sedan and it bolted right in.
The published data on the Red Head says it raised compression from 5:1 to 6.5:1 and increased horsepower from 70 to 76. The engine was 190 cubic inches. The largest Plymouth six was 230, a 40 cubic inch increase. Larger Chrysler engines are too long to fit easily into these early cars, that's my opinion.
The flathead engines had such a simple cylinder head design that higher compression heads were a natural. Example was Ford, some of the V8s sold in high altitude places had higher compression heads. Soon they were popular, called "Denver heads". I believe Hudson had higher compression heads available for some of their engines. Then there was the aftermarket which was active even before WWII.
I think the Red Head was a simple substitution of one head for the other and don't know if it occurred at the factory or the dealership.
I am a hot rodder at heart and looking at that fine body I see it sporting a 236 cubic inch six with dual carbs, split exhaust and a high compression head. All were available for the Plymouth 6 in the '50s. Horsepower would be between 120 and 140 which could make quite a difference in driveability.
R.
Re: Help Identifying rear end in 33 Dodge!?!? [Re: Mr.Mopar] #2209004
12/06/16 10:45 PM
12/06/16 10:45 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
The 23 on the lower right side of the center housing casting is what identifies the rear end type. Spicer or Dana corporation, depending on what year it was produced. Very likely it came from a Studebaker as they used them in a lot of their lower powered cars. The higher number on the center casting, such as 27, 30, 44 and so on get stronger as the number increases, but the overall width (at least on Stude) remain the same. Studebaker, as well as Rambler used that style of drum for most all of their cars.
