A500 tranny problems.......still
#215210
02/05/09 05:49 PM
02/05/09 05:49 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
I'm gonna try this question here as I need some quick suggestions and the truck forum isn't very busy most the time. Click here for the thread in the truck forum.
Re: A500 tranny problems.......still
[Re: ProSport]
#215213
02/05/09 07:42 PM
02/05/09 07:42 PM
Posts: 1,532 off the grid
340B5
off the grid
You might try cleaning connections at the PCM and at the trans. The PCM reads load and speed through the Throttle Position Sensor and the Vehicle Speed Sensor and controls transmission shifts. As for the enlarged hole, I would think it would only make a very slight difference. Also on this old of a truck, try cleaning every ground connection you can find.
Yeah, it's got a smallblock.
[Re: rtstreet]
#215219
02/10/09 08:42 PM
02/10/09 08:42 PM
ProSport
Akron, Ohio
Well, after diagnostics the tranny shop thinks the front pump is bad. Excuse me while I go pull my hair out.
[Re: dartman366]
#215223
02/11/09 12:05 AM
02/11/09 12:05 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Sound's like it's time for a new shop.
Give Mike Karas a call.
[Re: max_maniac]
#215224
02/15/09 11:25 PM
02/15/09 11:25 PM
ProSport
Akron, Ohio
Karas did rebuild it for me, he always does good work.
I took the truck to Richards Transmissions for a complete diagnosis. Another $116 later I was told the tranny filter element had sucked up into a hole somewhere and was blocking the fluid. New filter and I've driven it several days now with no problems, thank goodness. I didn't want to have to pull this tranny again, and I'm sure Butch doesn't either. LOL!
