A500 tranny problems.......still #215210
02/05/09 05:49 PM
02/05/09 05:49 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I'm gonna try this question here as I need some quick suggestions and the truck forum isn't very busy most the time.
Click here for the thread in the truck forum.
Re: A500 tranny problems.......still [Re: ProSport] #215211
02/05/09 06:49 PM
02/05/09 06:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What gear change does it have the problem on?
Re: A500 tranny problems.......still [Re: dizuster] #215212
02/05/09 07:17 PM
02/05/09 07:17 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Both
Re: A500 tranny problems.......still [Re: ProSport] #215213
02/05/09 07:42 PM
02/05/09 07:42 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
You might try cleaning connections at the PCM and at the trans. The PCM reads load and speed through the Throttle Position Sensor and the Vehicle Speed Sensor and controls transmission shifts. As for the enlarged hole, I would think it would only make a very slight difference. Also on this old of a truck, try cleaning every ground connection you can find.
Yeah, it's got a smallblock.
Re: A500 tranny problems.......still [Re: 340B5] #215214
02/05/09 08:09 PM
02/05/09 08:09 PM
CT
turbocolt2.4L Offline
CT
hook up a scanner and check live data look at gov pressure vs des press, also output sensor rpm the hole in plate is most likely for the rev,checkball.also check to see that the tv cable is returning all the way and moves free.
Re: A500 tranny problems.......still [Re: turbocolt2.4L] #215215
02/05/09 09:06 PM
02/05/09 09:06 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
The tranny guy did mention that the check ball had something to do with reverse.
Re: A500 tranny problems.......still [Re: ProSport] #215216
02/06/09 12:51 AM
02/06/09 12:51 AM
pa
K
Kyle Reasbeck Offline
K
pa
i dont think a PCM would cause that at all....the chrysler trans i've seen with that problem have been two things:
low on fluid
governor pack
I say that because i think you can get a governor "pack" off of chrysler which takes care of the sensor and solenoid...if you PM me your VIN and details i can check...
Re: A500 tranny problems.......still [Re: ProSport] #215217
02/06/09 01:28 AM
02/06/09 01:28 AM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Not sure why your trans guy could not get a SEPARATOR PLATE and if the plate holes are to big it or dont seal, it will cause problems.
http://www.transmissionpartsusa.com/48RE_valve_body_separator_plate_2003_06_p/500-05491895c.htm
http://cgi.ebay.com/ebaymotors/CHRYSLER-VALVE-BODY-SEPARATOR-PLATE,-(A12747EB)_W0QQitemZ370151732357QQcmdZViewItemQQimsxZ20090129?IMSfp=TL090129125011r12005
Re: A500 tranny problems.......still [Re: Sub95] #215218
02/06/09 02:21 AM
02/06/09 02:21 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
call i build about two a week (500, 518, 727, 904, etc.) 615 573 2738
Re: A500 tranny problems.......still [Re: rtstreet] #215219
02/10/09 08:42 PM
02/10/09 08:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Well, after diagnostics the tranny shop thinks the front pump is bad.
Excuse me while I go pull my hair out.
Re: A500 tranny problems.......still [Re: ProSport] #215220
02/10/09 08:52 PM
02/10/09 08:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Diagnostics can be tough. I wish I could help you but I cant. It sucks that they THINK its the front pump. That means it may not be. I hope their right for you. mike
Re: A500 tranny problems.......still [Re: ProSport] #215221
02/10/09 09:07 PM
02/10/09 09:07 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Well, after diagnostics the tranny shop THINKS the front pump is bad.
WTH...........
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: A500 tranny problems.......still [Re: Butch] #215222
02/10/09 10:20 PM
02/10/09 10:20 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sound's like it's time for a new shop.
Re: A500 tranny problems.......still [Re: dartman366] #215223
02/11/09 12:05 AM
02/11/09 12:05 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Give Mike Karas a call.
Re: A500 tranny problems.......still [Re: max_maniac] #215224
02/15/09 11:25 PM
02/15/09 11:25 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Karas did rebuild it for me, he always does good work.
I took the truck to Richards Transmissions for a complete diagnosis. Another $116 later I was told the tranny filter element had sucked up into a hole somewhere and was blocking the fluid. New filter and I've driven it several days now with no problems, thank goodness. I didn't want to have to pull this tranny again, and I'm sure Butch doesn't either. LOL!
