E-body weights please! #215099
02/05/09 03:12 PM
02/05/09 03:12 PM
Anonymous OP
Anonymous OP
This has to do with another thread discussing the weights/perfomance of a couple of cars.
I'm curious, how many here have actually weighed their stock 'Cuda/Challengers?
There's a mis-conception that these cars weigh almost as much as a B-body when, in fact, my experience has been that they're lighter than a lot of A-bodies!
Please post your actual (not guesstimated!) weights!
'71 Cuda with A/C, P/S, Console, Buckets, full undercoat = 3,260 lbs.
Same car with 440 a/c compressor removed = 3,440 lbs.
Re: E-body weights please! #215100
02/05/09 06:33 PM
02/05/09 06:33 PM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
GY3.... look at your numbers, they don't add right
My '74 cuda with a 400/727, 8 3/4, no a/c, no spare, no carpet or back seat was 3410 on Milan Dragway's crappy scale. the Title says 3210 w/sb, a/t, a/c, ps, pb, so.......... ?
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: E-body weights please! [Re: Todd_DesMarais] #215101
02/05/09 06:44 PM
02/05/09 06:44 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
At 3260 I think you need to double check that against another scale.
Re: E-body weights please! [Re: scatpacktom] #215102
02/05/09 07:02 PM
02/05/09 07:02 PM
Anonymous OP
Anonymous OP
Why not?
SB = 3260
BB = 3440
What doesn't add up about that?!
They were both done at the local grain elevator and my truck has been on multiple elevator scales and weighed the same.
180 lbs diff with 150 being the BB and 30 or so being the 904 to 727?
Re: E-body weights please! #215103
02/05/09 08:12 PM
02/05/09 08:12 PM
N. Ca.
floorit426 Offline
floorit426  Offline
N. Ca.
I think the difference between the two is accurate, but my experience (for what it's worth), is that both are about 200lbs. heavier than that.
Re: E-body weights please! [Re: floorit426] #215104
02/05/09 08:26 PM
02/05/09 08:26 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
every street challenger and cuda in the race forum weighs over 3750!!! 3400 no way
weight now in my sig because i've been killing myself to make it lighter
Re: E-body weights please! #215105
02/05/09 08:27 PM
02/05/09 08:27 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
3500lbs with 1/2 tank of gas. Small block with aluminum heads & intake. TTI headers, power steering, stock three row radiator. 8 3/4 rear end. No AC. 5- speed Tremec, supposed to be about 25 lbs. lighter than 833 4- speed. The bucket seats aren't stock, but they are similar in weight. Car was weighed on a grain scale certified accurate to +or- 20 lbs. FWIW my old '74 Duster after significant dieting came in at 3380lbs. on the same scale with the same fuel load. Both weights are minus driver.
Re: E-body weights please! [Re: 5spdcuda] #215106
02/05/09 08:47 PM
02/05/09 08:47 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
FWIW The T/A in my sig weighs 3250.Has heater delete,radio delete,alum 4 speed,alum flywheel and pressure plate,man disc brakes,man steering,spool among other little "things".
Also I have a 72 340 Cuda that weighs 3570.It is a completly stock car.Undercoated,PS,man drum brakes,torqueflite,console,22 inch rad
Re: E-body weights please! [Re: scatpacktom] #215107
02/05/09 09:09 PM
02/05/09 09:09 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I understand about "little things". I did quite a few to my Duster to get the weight down, nothing readily visible, but I still took at least 150 lbs. if not more out of it. Keep in mind my cars are four season cars that get driven regularly except for ice,snow and generally rotten weather, so heaters, windshield wipers etc. are necessary. I don't need a stereo [engine sounds pretty good going up or down the gears ], but I have one anyway. I also forgot to mention that both cars had frame connectors. All things considered I think my weights are pretty representative of what a person could expect from these cars in a truly streetable condition.
Obviously if you get serious a lot more weight can be removed. A friend of mine got over 500lbs. out of his '72 Road Runner.
Re: E-body weights please! [Re: 5spdcuda] #215108
02/05/09 09:18 PM
02/05/09 09:18 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I don't doubt the accuracy of your number but your car sounds heavy compared to
1970 Barracuda (Cuda Clone)
440 W/Iron heads
Aluminum intake
26 inch mopar rad
manual steering
manual drum brakes
Aluminum (Centerline wheels)
No sway bar
Frame connectors
8.75 rear
727 TF
No fiberglass
1/2 tank gas
No driver
Weighed on certified +/- 10 pound scale 3450
Re: E-body weights please! #215109
02/05/09 09:40 PM
02/05/09 09:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
70 Challenger, 426 Hemi, shaker, automatic, Dana 60, factory rear spoiler, 15X7 rallye wheels, factory AM8trk, headers, stock exhaust, no bondo 3830lbs with half tank of fuel.
On the very same scale my 67 GTX 440 automatic weighed 3700lbs, my 68 340S, 4 speed, M.B. M.S. was 3000lbs.
Sheldon
Re: E-body weights please! [Re: Pacnorthcuda] #215110
02/05/09 11:14 PM
02/05/09 11:14 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
No question about it, my car is heavier than I would like it to be. That's just the way it is. Obviously a big block with iron heads is a good deal heavier than a small block with aluminum heads and intake. So where's the difference? Well here are a few possibilities. Power steering vs. manual; big difference. Disc brakes with 11.75 rotors vs. drums; some difference. 1.25 front anti-roll bar vs. none; it matters. Not all 26 in. radiators are the same. My Duster had a two row 26 in. radiator that was much lighter than the 26 in. three row in the 'Cuda. I thought about using the two row, but this was my first experience running aluminum heads on an iron block and I could just see getting stuck in traffic on a 100* day, so I chickened out and went with the three row. Last I am not sure just when they started putting door guard beams in the doors, but I definitely have them and the doors are heavy. Maybe somebody else has some ideas. All I can say is that in my experience "E" bodies weigh more than late '60s "A" bodies. About the same as late '60s "B" bodies, and less than '71 up "B" bodies. This of course assumes comparing cars with similar options.
Re: E-body weights please! [Re: 5spdcuda] #215111
02/05/09 11:42 PM
02/05/09 11:42 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Whats a small block convertable weigh in at 4000?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: E-body weights please! #215112
02/06/09 09:44 AM
02/06/09 09:44 AM
Clarkston,MI
super street
super street
Clarkston,MI
Why not?
SB = 3260
BB = 3440
Your first post doesn't say that the '71 is a SB. it makes a little more sense now that you clarified that.
Re: E-body weights please! [Re: Todd_DesMarais] #215113
02/06/09 11:20 AM
02/06/09 11:20 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i had both of my 70 cudas weighed on same scale
#1 1970 barracuda convertable 383 auto with air compleatly stock 1/4 tank of gas was 3660 with out my big butt in it
#2pro street(1970 cuda) car back halfed 4 link,
cell 8 point cage 2 nos bottles, alum back floor/trunk/wheel tubbs, 15x15 pro stars,plastic seats, fiberglass fenders,header panel,valance,340/auto,manual steer/brakes,fiberglass hood weighed 3,000 lbs with 6 gal of fuel and me not in it
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: E-body weights please! [Re: toplescuda] #215114
02/06/09 11:57 AM
02/06/09 11:57 AM
Anonymous OP
Anonymous OP
Mine was almost identical in equipment save for cast iron intake and no subframe connectors (probably cancel each other out). Oh yeah, added P/S to boot.
Most of them have a cage and subframe connectors as well. That adds at least +/- 150?
My experience has always been that Challengers will be heavier as well. I don't really know why either.
Re: E-body weights please! #215115
02/06/09 12:17 PM
02/06/09 12:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Thanks for posting this. I don't know if we're all that much closer to a definative answer, but it IS interesting.
I'm thinking that the discrepancies are to do with options, modifications AND different scales. I'm gonna weigh my Super Bee and my Cuda on certified CAT scales in the spring.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: E-body weights please! [Re: scatpacktom] #215116
02/06/09 12:23 PM
02/06/09 12:23 PM
DPelletier Offline
DPelletier  Offline
I have to agree that it's pretty hard to believe that GY3's undercoated A/C car could be 3260. I'm NOT questioning anybodies honesty, but I think the scale was probably off.
Cheers,
Re: E-body weights please! #215117
02/06/09 12:35 PM
02/06/09 12:35 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Everything else being equal a Challenger should weigh more than a Barracuda since they have two inches more wheelbase. FWIW I think this also gives them a little better weight distribution. Of course on a real race car overall weight and weight distribution can vary considerably from production.
Re: E-body weights please! [Re: 5spdcuda] #215118
02/06/09 01:15 PM
02/06/09 01:15 PM
Anonymous OP
Anonymous OP
The car was weighed (in smallblock form) in Newton, KS for the 3260 at the grain elevator and (in BB form) in Valley Center, KS at the grain elevator.
The difference of 180 lbs. is right on from what I've seen from other cars going from SB/904 to BB/727.
