E-body weights please!
#215099
02/05/09 03:12 PM
02/05/09 03:12 PM
This has to do with another thread discussing the weights/perfomance of a couple of cars.
I'm curious, how many here have actually weighed their stock 'Cuda/Challengers?
There's a mis-conception that these cars weigh almost as much as a B-body when, in fact, my experience has been that they're lighter than a lot of A-bodies!
Please post your actual (not guesstimated!) weights!
'71 Cuda with A/C, P/S, Console, Buckets, full undercoat = 3,260 lbs.
Same car with 440 a/c compressor removed = 3,440 lbs.
Re: E-body weights please!
#215100
02/05/09 06:33 PM
02/05/09 06:33 PM
Posts: 477 Clarkston,MI
Todd_DesMarais
super street
super street
Clarkston,MI
GY3.... look at your numbers, they don't add right My '74 cuda with a 400/727, 8 3/4, no a/c, no spare, no carpet or back seat was 3410 on Milan Dragway's crappy scale. the Title says 3210 w/sb, a/t, a/c, ps, pb, so.......... ?
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
"ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
[Re: scatpacktom]
#215102
02/05/09 07:02 PM
02/05/09 07:02 PM
Why not?
SB = 3260 BB = 3440
What doesn't add up about that?!
They were both done at the local grain elevator and my truck has been on multiple elevator scales and weighed the same.
180 lbs diff with 150 being the BB and 30 or so being the 904 to 727?
[Re: floorit426]
#215104
02/05/09 08:26 PM
02/05/09 08:26 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
every street challenger and cuda in the race forum weighs over 3750!!! 3400 no way
weight now in my sig because i've been killing myself to make it lighter
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 5spdcuda]
#215106
02/05/09 08:47 PM
02/05/09 08:47 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
FWIW The T/A in my sig weighs 3250.Has heater delete,radio delete,alum 4 speed,alum flywheel and pressure plate,man disc brakes,man steering,spool among other little "things".
Also I have a 72 340 Cuda that weighs 3570.It is a completly stock car.Undercoated,PS,man drum brakes,torqueflite,console,22 inch rad
[Re: 5spdcuda]
#215108
02/05/09 09:18 PM
02/05/09 09:18 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
I understand about "little things". I did quite a few to my Duster to get the weight down, nothing readily visible, but I still took at least 150 lbs. if not more out of it. Keep in mind my cars are four season cars that get driven regularly except for ice,snow and generally rotten weather, so heaters, windshield wipers etc. are necessary. I don't need a stereo [engine sounds pretty good going up or down the gears ], but I have one anyway. I also forgot to mention that both cars had frame connectors. All things considered I think my weights are pretty representative of what a person could expect from these cars in a truly streetable condition. Obviously if you get serious a lot more weight can be removed. A friend of mine got over 500lbs. out of his '72 Road Runner.
I don't doubt the accuracy of your number but your car sounds heavy compared to 1970 Barracuda (Cuda Clone) 440 W/Iron heads Aluminum intake 26 inch mopar rad manual steering manual drum brakes Aluminum (Centerline wheels) No sway bar Frame connectors 8.75 rear 727 TF No fiberglass 1/2 tank gas No driver
Weighed on certified +/- 10 pound scale 3450
#215109
02/05/09 09:40 PM
02/05/09 09:40 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
70 Challenger, 426 Hemi, shaker, automatic, Dana 60, factory rear spoiler, 15X7 rallye wheels, factory AM8trk, headers, stock exhaust, no bondo 3830lbs with half tank of fuel. On the very same scale my 67 GTX 440 automatic weighed 3700lbs, my 68 340S, 4 speed, M.B. M.S. was 3000lbs.
Sheldon
[Re: Todd_DesMarais]
#215113
02/06/09 11:20 AM
02/06/09 11:20 AM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i had both of my 70 cudas weighed on same scale #1 1970 barracuda convertable 383 auto with air compleatly stock 1/4 tank of gas was 3660 with out my big butt in it #2pro street(1970 cuda) car back halfed 4 link, cell 8 point cage 2 nos bottles, alum back floor/trunk/wheel tubbs, 15x15 pro stars,plastic seats, fiberglass fenders,header panel,valance,340/auto,manual steer/brakes,fiberglass hood weighed 3,000 lbs with 6 gal of fuel and me not in it
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#215114
02/06/09 11:57 AM
02/06/09 11:57 AM
Mine was almost identical in equipment save for cast iron intake and no subframe connectors (probably cancel each other out). Oh yeah, added P/S to boot.
Most of them have a cage and subframe connectors as well. That adds at least +/- 150?
My experience has always been that Challengers will be heavier as well. I don't really know why either.
#215115
02/06/09 12:17 PM
02/06/09 12:17 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Thanks for posting this. I don't know if we're all that much closer to a definative answer, but it IS interesting.
I'm thinking that the discrepancies are to do with options, modifications AND different scales. I'm gonna weigh my Super Bee and my Cuda on certified CAT scales in the spring.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: scatpacktom]
#215116
02/06/09 12:23 PM
02/06/09 12:23 PM
DPelletier
I have to agree that it's pretty hard to believe that GY3's undercoated A/C car could be 3260. I'm NOT questioning anybodies honesty, but I think the scale was probably off.
Cheers, Dave
1974 'Cuda
[Re: 5spdcuda]
#215118
02/06/09 01:15 PM
02/06/09 01:15 PM
The car was weighed (in smallblock form) in Newton, KS for the 3260 at the grain elevator and (in BB form) in Valley Center, KS at the grain elevator.
The difference of 180 lbs. is right on from what I've seen from other cars going from SB/904 to BB/727.
