Re: Which rocker shaft hold down?
[Re: 67_Satellite]
#2150741
09/08/16 11:33 PM
09/08/16 11:33 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I bought the Mancini ones for my small block. They are ultra beefy but the studs that come with them are pretty lame, i don't think a single one of them was straight and they could have been a little longer for my Edelbrock heads and Erson Rocker setup. But they worked and have lots of miles on them.
68 Barracuda Formula S 340
[Re: 67_Satellite]
#2150778
09/09/16 12:25 AM
09/09/16 12:25 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I used the parts from Mancini.The studs were fine. 440 engine.
[Re: 67_Satellite]
#2150945
09/09/16 12:17 PM
09/09/16 12:17 PM
Posts: 30,995 Oregon
AndyF
What would be a good upgrade from the stock ones I am using now?Aluminum, steel,billet? Any to avoid? Running Comp pro magnum rocker arms and will have about 350 lbs. open pressure. Well it isn't that easy since the width depends on the rocker arms. I prefer the steel hold downs made from hex stock like the ones that Hughes and Harland sell but no guarantee that anything will work right out of the box. Be prepared to shim or machine the parts to fit.
[Re: 67_Satellite]
#2151074
09/09/16 02:49 PM
09/09/16 02:49 PM
Posts: 5,161 CT
GTX MATT
CT
I bought the ones hughes sells for my big block. Don't buy them if you're going to run solid spacers/shims, they fit on the stud pretty sloppy and you have to reset them all up every time you take the rockers off. Ask me how I know, I should just run spacer springs and be done with it
[Re: 67_Satellite]
#2151092
09/09/16 03:10 PM
09/09/16 03:10 PM
Posts: 561 USA
B3RE
USA
What would be a good upgrade from the stock ones I am using now?Aluminum, steel,billet? Any to avoid? Running Comp pro magnum rocker arms and will have about 350 lbs. open pressure. These, along with the corresponding geometry correction.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: tboomer]
#2151199
09/09/16 06:25 PM
09/09/16 06:25 PM
Posts: 561 USA
B3RE
USA
Mike...Have you ever considered being a Moparts sponsor? Yes I have ,Ted. There always seems to be something expensive that takes priority though. Can you PM me with some details, prices, etc.?
Mike Beachel
[Re: 67_Satellite]
#2151369
09/10/16 12:04 AM
09/10/16 12:04 AM
Chris2581
Jacksonville, FL
Gus, Where did you get the spacer rings from?
[Re: 67_Satellite]
#2151396
09/10/16 12:45 AM
09/10/16 12:45 AM
Posts: 43 Kansas
Burnincircles
Kansas
I built my own out of 1018 steel. Mine wrap the shaft about 200°. This keeps them from falling off the shaft when not bolted to the head. Just a personal preference. I used ARP studs but came up with 5/16-18 flange nuts that use a 9/16 wrench size to put more surface on the contact area.
[Re: Chris2581]
#2151420
09/10/16 01:09 AM
09/10/16 01:09 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Gus, Where did you get the spacer rings from? I'm lucky enough to live near the Harlan Sharp machine shop and I just took one of my heads over there and we set my rockers up on their bench. I think you could get the same ones from Mancini Racing though. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
