ALIGNMENT SHOP #2149682
09/07/16 03:38 PM
09/07/16 03:38 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Getting the tires mounted on the wheels tomorrow. I have talked to a couple of shops and not impressed with them. Can anyone recommend an alignment shop. I am in Diamond Bar,Ca 91765. This is an original owner 70 440 6bbl Cuda 4sp. Just finished a full resto.
Thanks,Rod
Real Men shift for themselves
Re: ALIGNMENT SHOP [Re: 1DGEMAN] #2149775
09/07/16 06:01 PM
09/07/16 06:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not familiar with Diamond Bar area shops. But there should be something somewhat close that works older and speciality stuff. Just need to keep asking around.
Re: ALIGNMENT SHOP [Re: 1DGEMAN] #2149963
09/07/16 10:27 PM
09/07/16 10:27 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
Ask other car guys who they use and if they are happy with them, also talk to body shops that restore older cars, they usually have a shop or know of a specific person at a shop that they trust to do suspension and alignment work. Its getting harder to find someone who knows how to set the camber and caster, or even straighten the steering wheel, on these older cars.
Re: ALIGNMENT SHOP [Re: 1DGEMAN] #2149966
09/07/16 10:30 PM
09/07/16 10:30 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I was lucky enough to have a fellow member come over and we (well, him mostly laugh2 ) did the alignment in the garage (magnet mount caster camber gauge and I had made a toe gauge myself along with making my own ground twist plates.
I'll ask around a couple friends around here in OC and see who they used...
Re: ALIGNMENT SHOP [Re: 1DGEMAN] #2151332
09/09/16 11:14 PM
09/09/16 11:14 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Suggest U call Matt Keane @ Glendora Dodge. He has been a Mopar guy for many, many years and knows that area quite well and can give U a recommendation.... 888.379.1925
Just my $0.02... wink
