Re: 1970 B Body A/C
[Re: Turbo383]
#2149424
09/07/16 09:52 AM
09/07/16 09:52 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Could be, it's plastic that is basically glued together and it WILL fail eventually.
Hopefully it's available aftermarket, otherwise $$$$ .
Re: 1970 B Body A/C
[Re: twodoorpost]
#2150375
09/08/16 02:32 PM
09/08/16 02:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you want to turn the compressor to turn on in the defrost position, then you need switch # 3895790, which is a later switch. Standard Brands HS-101 about $50 at RockAuto.
