08 ram CRUISE NOT WORKING--TECHS HELP THANKS! #2149083
09/06/16 08:10 PM
09/06/16 08:10 PM
crabman173 OP
crabman173 OP
08 RAM 1500 HEMI GREAT TRUCK ABOUT 140k MILES AND CRUISE CONTROL WILL NOT SET NO GREE LIGHT--HORN AND OTHER STUFF WORKS SO GUESSING IT IS NOT THE CLOCK SPRING BUT NEED IDEAS SO I CAN FIX HER THANKS
Re: 08 ram CRUISE NOT WORKING--TECHS HELP THANKS! [Re: ] #2149220
09/06/16 10:46 PM
09/06/16 10:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just because the horn works don't rule out the clock spring.
Re: 08 ram CRUISE NOT WORKING--TECHS HELP THANKS! [Re: ] #2149858
09/07/16 07:33 PM
09/07/16 07:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Everything on the wheel (and everything that could be on the wheel) has a separate circuit through the clock spring, any number of these circuits can be bad. Gene
Re: 08 ram CRUISE NOT WORKING--TECHS HELP THANKS! [Re: ] #2150104
09/08/16 12:58 AM
09/08/16 12:58 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
x3 for the clockspring.
Known trouble-maker in more than just Dodges.
Mo' Farts
Moderated by "tbagger".
Re: 08 ram CRUISE NOT WORKING--TECHS HELP THANKS! [Re: ] #2150660
09/08/16 10:01 PM
09/08/16 10:01 PM
UP
finn Offline
finn  Offline
UP
Whenn the front unit bearing failed on my Ram, the play took out the wheel speed sensor and I Lost the cruise control.
I think it was when the right bearing failed.
Took out the pads and rotor too.
