ID this part please: Challenger fender/headlight area #2149051
09/06/16 07:26 PM
09/06/16 07:26 PM
Third Stone from the Sun
Scotts72Rallye Offline OP
It's been some time since I took the fender's off my '72 Challenger and I forgot what this double sided screw does. shruggy It's located in the headlight area. If you know where I can get a new one that would be great too! up
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2149258
09/06/16 11:46 PM
09/06/16 11:46 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
IIRC it goes into the grill
Re: ID this part please: Challenger fender/headlight area [Re: Morty426] #2149264
09/06/16 11:51 PM
09/06/16 11:51 PM
Maryland
MoparMike1974 Offline
Maryland
It threads into the fiberglass surround and attaches it to the fender. The grill mounts in the FG surround.
Re: ID this part please: Challenger fender/headlight area [Re: MoparMike1974] #2149644
09/07/16 03:05 PM
09/07/16 03:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
To me the fiberglass surround is the grill, but I agree up
Re: ID this part please: Challenger fender/headlight area [Re: Morty426] #2149734
09/07/16 04:57 PM
09/07/16 04:57 PM
Thanks guys! up Anyone know where to get a new one? Mine has seen better day's. frown
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2149821
09/07/16 06:57 PM
09/07/16 06:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What's wrong with it? It's not a standard thread on the one side. The thread is special to screw into the fiberglass header panel. The wheel well side is standard thread and uses a nut w/captive washer to hold the header panel.
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2149948
09/07/16 10:14 PM
09/07/16 10:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
tried to see if i might have one in my re-plated hardware but no luck
Re: ID this part please: Challenger fender/headlight area [Re: burdar] #2150042
09/07/16 11:46 PM
09/07/16 11:46 PM
I sold the fenders and forgot to keep the screws for the new AMD set. whiney
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Morty426] #2150045
09/07/16 11:49 PM
09/07/16 11:49 PM
Thanks for checking! up
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2151706
09/10/16 04:18 PM
09/10/16 04:18 PM
Maryland
Maryland
I have a couple extra fg surrounds in my parts storage. They should have the studs in them...at least a couple I would guess. Shoot me a pm.
Re: ID this part please: Challenger fender/headlight area [Re: MoparMike1974] #2153941
09/13/16 08:10 PM
09/13/16 08:10 PM
If anyone has a pair laying around they want to get rid of please send me a pm. Thanks!!!
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2157431
09/19/16 02:59 PM
09/19/16 02:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Did you ever find those studs? I was at a Theisen's(Home Farm Auto)store yesterday and saw something that might work for you. It's just a double sided stud. 1/4-20 on one end and lag bolt threads on the other. You could just add a thick washer between the header panel and the fender.
Re: ID this part please: Challenger fender/headlight area [Re: burdar] #2157564
09/19/16 05:31 PM
09/19/16 05:31 PM
Yes and no! I'm buying one local from someone who has a fender for sale but will need a second. I'll be picking it up this Saturday. Since you mentioned that I'll stop by my local hardware store when I get the bolt/stud and see if they have a close match. Thanks for the idea burdar!!! up
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2164507
09/29/16 05:28 PM
09/29/16 05:28 PM
Well I picked up one local so here's a better picture. Looks like a hanger bolt with a fixed washer in the center. I took Burdar's advice and hit the local hardware store so I do have a back up plan if I don't find another original. The car won't be assembled anytime soon so no rush. up
UNDER CONSTRUCTION
Re: ID this part please: Challenger fender/headlight area [Re: Scotts72Rallye] #2165095
09/30/16 01:32 PM
09/30/16 01:32 PM
pa.
dan9 Offline
dan9  Offline
pa.
Those ones at the local hardware stores should be located in the stair rail section. They can be used to join railing sections together.
Re: ID this part please: Challenger fender/headlight area [Re: dan9] #2165209
09/30/16 05:37 PM
09/30/16 05:37 PM
Thanks Dan9! up
UNDER CONSTRUCTION
