Accelerator Pump Nozzles
#2148849
09/06/16 02:57 PM
09/06/16 02:57 PM
Posts: 5,161 CT
GTX MATT
CT
What are you running and what carb? I've got .040s on an 850 DP, it wants/needs more, but this seems like a lot.
Re: Accelerator Pump Nozzles
[Re: GTX MATT]
#2148863
09/06/16 03:12 PM
09/06/16 03:12 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
The bigger the size, the more fuel but it lasts a shorter time. The smaller size is a thinner stream but lasts longer. I know Patrick at Pro systems always uses large squirters. The 950 I just bought from him came with 40's all around. I swapped to 31 front, 35 back and my car really woke up in the 60 foot. This week before I race it I am going to put 31's in the back also and give that a try.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: GTX MATT]
#2148886
09/06/16 03:36 PM
09/06/16 03:36 PM
Posts: 43,159 Bend,OR USA
Cab_Burge
[Re: GTX MATT]
#2148920
09/06/16 04:30 PM
09/06/16 04:30 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My experience is that the 1.560 Venturi carbs usually need a lot of squirter. My ported 850 annular works well with 42 front/45 rear, and when I had it on my 340 I ran 47/47. I like to use the hollow screw on anything larger than a 37.
[Re: fast68plymouth]
#2148949
09/06/16 05:13 PM
09/06/16 05:13 PM
Posts: 5,161 CT
GTX MATT
CT
My experience is that the 1.560 Venturi carbs usually need a lot of squirter. My ported 850 annular works well with 42 front/45 rear, and when I had it on my 340 I ran 47/47. I like to use the hollow screw on anything larger than a 37. This is also an annular, 9380. That makes me feel better about it. Are you running a 30 or 50 cc pump? I do have the hollow screws. Cab the arms are adjusted correctly, sadly.
[Re: GTX MATT]
#2149339
09/07/16 01:30 AM
09/07/16 01:30 AM
fast68plymouth
So. Burlington, Vt.
30cc on both ends.
My carb seems to like a big shot at the hit, but it doesn't need much duration, so I get by with the 30cc pumps.
#2149716
09/07/16 04:24 PM
09/07/16 04:24 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
My Quickfuel 1050AN has 37's on the primary and 42's on the secondary. Doesn't seem to affect my 60's by going smaller because I leave on the secondary's,(stick car). 50 cc pumps front and back.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
