Finding a rebuilt 96 360 pickup engine near Kansas City
#2148365
09/05/16 10:35 PM
09/05/16 10:35 PM
Posts: 444 Loma Linda, MO
7812845
Loma Linda, MO
My son has my old 96 Dodge pickup and evidently the old 360 is going thru oil really quickly, like a quart every 100 miles. He's in KC and would like to find a good rebuilt 360 for it. That is about his only option and can't be without a second vehicle for an extended amount of time. Any and all ideas appreciated. Thanks
2020 RAM Longhorn 4x4 2022 Jeep Grand Cherokee Overland
Re: Finding a rebuilt 96 360 pickup engine near Kansas City
[Re: 7812845]
#2148369
09/05/16 10:37 PM
09/05/16 10:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sounds like a leak issue not a new engine issue.
[Re: Supercuda]
#2148374
09/05/16 10:41 PM
09/05/16 10:41 PM
7812845
Loma Linda, MO
Valve covers have a very small leak, not even leaving a spot on the ground. Even worse no black oil smoke like it's burning it or on start up, nothing.?????
[Re: BEINGmeISaCRIME]
#2148838
09/06/16 02:48 PM
09/06/16 02:48 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Has the intake plenum been checked? Its very common for those to blow the gasket and cause oil consumption. If that is the issue, a functioning catalytic converter will burn up the oil and you will not see a leak on the ground.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
