Page 2 of 3 1 2 3
Re: leaf springs with ladder bars? [Re: emarine01] #214820
02/05/09 06:49 PM
02/05/09 06:49 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
You need to use the floaters, you are bound up. The ladders and springs are travelling on different radii. In mud you probably don't notice it much, but on pavement with slicks you would be in the wall.
Re: leaf springs with ladder bars? [Re: cgall] #214821
02/05/09 07:07 PM
02/05/09 07:07 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
What Mud Pit do you race at? Lee County Mud Motorsports is 2 miles from my house.
One day I will have something cool here.
Re: leaf springs with ladder bars? [Re: emarine01] #214822
02/06/09 11:32 AM
02/06/09 11:32 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
I still run leaf springs with a four link at 9.18 and 144 MPH.
Re: leaf springs with ladder bars? [Re: RAT PATROL] #214823
02/06/09 11:51 AM
02/06/09 11:51 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it must be working but I have ask why would you do that
Re: leaf springs with ladder bars? [Re: RAT PATROL] #214824
02/06/09 11:52 AM
02/06/09 11:52 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
my pops car has been 1.19 60' 8.30 @ 170 3400lbs, 10.5w's. On ladder bars, floaters, and factory leaf springs. It does work.
Re: leaf springs with ladder bars? [Re: sdaurity] #214825
02/06/09 12:11 PM
02/06/09 12:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you can throw enough HP at something and still go fast. but what is the reason for running a set up like that when there is better ways to do it? is it because of the class, to save a few bucks? etc. just curious?
Re: leaf springs with ladder bars? [Re: Quicktree] #214826
02/06/09 12:27 PM
02/06/09 12:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You might want to look into cal-trac's. Don't know if they make them for heavier trucks but you could give them a call. Your right about muddin and drag racing, it about putting the tires to the ground .
Re: leaf springs with ladder bars? [Re: rowin4] #214827
02/06/09 12:35 PM
02/06/09 12:35 PM
In the mud somewhere
dodgedude4x4 Offline
Float the front of the ladder bars,
Done it before , works well.......
Re: leaf springs with ladder bars? [Re: dodgedude4x4] #214828
02/06/09 01:04 PM
02/06/09 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be the equivalent to slapper bars
Re: leaf springs with ladder bars? [Re: emarine01] #214829
02/06/09 01:58 PM
02/06/09 01:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
You need a set of sliders on your set up instead of a floater kit,IMHO We used them years ago on a drag car with ladder bars, it would hook up in a mud pit in the middle of a rain storm It least it seemed like it would
Re: leaf springs with ladder bars? [Re: Cab_Burge] #214830
02/06/09 04:30 PM
02/06/09 04:30 PM
nc
E
emarine01 Offline OP
E
nc
We have sliders @ the back of leafs , they let the rear end of the leaf flex a little but still too stiff , yanked the leafs out this morning to get some clean measurements , going coilover would be really easy but that boots us out of class , I can build floaters for spring over axle or change out to a longer spring to match my IC< MR P > or I can go coil spring like a chebby and stay in my class? Got 2 weeks to figure it out , I think the 4 links work with leafs cause of the 4 hiem joints pivot , the ladder bar is like a solid truss , not much give ,I have never raced at Lee Co. , they run mostly hill & hole , they have a flat track but only ran rails last year, if they open the flat up we will go its about 2hr drive. Well now my mess is apart so keep the ideas comming
Re: leaf springs with ladder bars? [Re: emarine01] #214831
02/06/09 05:14 PM
02/06/09 05:14 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
a friend of mine has a old super stock camaro with old SRD ladder bars instead of using floaters they have rollers one on top and one below the spring that come off of mounts on the axle you could make something like that for a spring over axle
Re: leaf springs with ladder bars? [Re: NoFrills] #214832
02/06/09 06:46 PM
02/06/09 06:46 PM
nc
E
E
nc
It looks like comp eng makes a bolt on floater for spring under axle ,It looks like to me that once the spring purch is cut off it doesent matter weather its above or below the axle , the hight dosent look too bad?
Re: leaf springs with ladder bars? [Re: emarine01] #214833
02/06/09 09:18 PM
02/06/09 09:18 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
you see this car..
very old school gasser..uses the stock leaf suspension with long set of ladder bars and NO floaters..
thats what they did back then and thats whats still on this car...he uses a BOP rear(saginaw 9 1/4") that uses a welded seamed axle housing...
the two different motions or archs of rthe leaves and the ladder bars caused the seam to split open on the axle housing...
just so you know what can happen without a floater to allow the axle to rotate with two oposing forces...
I did fi the rear for him but he was missing pieces from his floater kit so I beefed the axle housing and the ladder bar connection points till he gets the parts or revises the rear suspension..
that 56 goes high nines and I cant figure out how it still passes tech...
Re: leaf springs with ladder bars? [Re: smokinwoody] #214834
02/06/09 09:31 PM
02/06/09 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
you see this car..
I'm sure it has enough IC before it binds up that
allows it to hook.... but then again its busting
up parts doing it
Re: leaf springs with ladder bars? [Re: RAT PATROL] #214835
02/06/09 09:34 PM
02/06/09 09:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
still no body has answered why you would want to set up a modern day race car like this
Re: leaf springs with ladder bars? [Re: smokinwoody] #214836
02/06/09 09:43 PM
02/06/09 09:43 PM
nc
E
E
nc
We used to have 60" ladder bars with the leafs and a shackle up front , we had too much nose lift , picked front wheels up , went to 33" bars to keep the front wheels from pulling ,<4x4 >, the short bars are way too stiff , had some give on the long bars ,I can see where it will tear stuff up
Re: leaf springs with ladder bars? [Re: emarine01] #214837
02/06/09 10:42 PM
02/06/09 10:42 PM
nc
E
E
nc
Hey, how do air shocks work , do they support the weight of the car? Kinda like coilovers but with air?
Re: leaf springs with ladder bars? [Re: emarine01] #214838
02/06/09 11:00 PM
02/06/09 11:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Air Shocks can assist with support. But they arent like coil overs. Or do you mean the air bag support type suspension.
Re: leaf springs with ladder bars? [Re: Quicktree] #214839
02/06/09 11:08 PM
02/06/09 11:08 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ill answer that!
The answer is Simplicity. Or so it seems when some first do it this way.
Then Later, in almost all cases that Ive seen. It all gets changed out.
Its all about the learning curve, we have all started somewhere on it.
Why do people start out with 8.3/4,s mike
Page 2 of 3 1 2 3
