904 oil pump passages #2148027
09/05/16 03:09 PM
09/05/16 03:09 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Looks like I'm not the only one here having problems with my 904 !
I see and hear a couple of people seeking informations for shifts problems.
Before I go and look for answers, I need to know what does what and where....
I tried to look for schematics on the oil pressure routing going out of the pump where they go and for what purpose.
A description of the holes around the oil pump
Where can I find infos and drawings on that ?
Dan
Re: 904 oil pump passages [Re: Wedgeman] #2148134
09/05/16 05:19 PM
09/05/16 05:19 PM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
I have a 72 Chry/Ply Service manual, and it has a few pages of fluid flow thru the trans in different valve positions.
Re: 904 oil pump passages [Re: Wedgeman] #2148218
09/05/16 07:58 PM
09/05/16 07:58 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok...
Re: 904 oil pump passages [Re: Wedgeman] #2148242
09/05/16 08:30 PM
09/05/16 08:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Using the air test diagram below you can blow air through the labeled case passages and feel where the air exits the case with the pump removed...match the ports in the case to the openings in the pump body.
