Gas pedal yeilds different results than...
#2148074
09/05/16 04:20 PM
09/05/16 04:20 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
...operating throttle from under the hood I just got my newly built 318 running. Its basically stock, albeit upgraded; Carter AVS from a '71 383 on a 273 castiron manifold, Comp's 340/360 cam and springs exhausting through magnum iron manifolds and duals out the rear. I need to do some tweeking to eliminate some hesitation, but by manually working the throttle I can get it to run up through WOT pretty smoothly. However, sitting in the car, working the gas pedal, Its as if I'm running a different car. run up is erratic and WOT sounds like its dropping a third of the cylinders. Help! What gives?? Its moving the same linkage!!
Re: Gas pedal yeilds different results than...
[Re: Scott Carl]
#2148081
09/05/16 04:29 PM
09/05/16 04:29 PM
RapidRobert
grab a helper & have him work the pedal with you under the hood to see what is different between the two operations.
[Re: Scott Carl]
#2148141
09/05/16 05:31 PM
09/05/16 05:31 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
If gas pedal is the same as my e body, it mounts on a pivot like a teeter totter. If your right foot contacts the bottom of the pedal only, you may see different results than if your foot is above the pivot point.
At one time I would very occasionally have the pedal stick to the floor on my 512 six pack(yes quite a thrill). Investigated linkage throughly, posted problem on forums,,,including this one to no success.
Could not get it to stick with engine not running,etc.etc
Then one day had my head under steering column to throughly check out the pedal assembly and found the cause.
If I would push pedal down by hand normally, it would return upon release.
However if I pushed down near the bottom of the pedal, causing it to 'pivot' down, the bottom of the pedal would barely catch on a ridge of decorative rubber built into the heel pad under the pedal, causing it not to release and return when I let up on the gas.
2 minutes with a Dremel grinder wheel and all is well.
Make certain that you are not merely 'toeing' the bottom of your pedal. Unlikely cause of your problem, but possible. I happen to be a 'toer' when driving and have at times found my toe slipping off the bottom of the pedal on my wife's suv.
Go Big Red,,,,born and raised in Lincoln. Spent many a weekend at the old Air Force base drag strip in Omaha back in the 60's in my misspent youth.
[Re: Scott Carl]
#2148262
09/05/16 08:49 PM
09/05/16 08:49 PM
Posts: 5,904 ohio
ruderunner
ohio
Along stummpys thought, is the engine grounded to the battery and body? Could it be that the throttle cable is acting like the engine to body ground? That could cause ignition break up as the cable moves and makes/breaks contact.
Angry white pureblood male
[Re: ruderunner]
#2148816
09/06/16 02:34 PM
09/06/16 02:34 PM
Posts: 5,164 CT
GTX MATT
CT
Along stummpys thought, is the engine grounded to the battery and body? Could it be that the throttle cable is acting like the engine to body ground? That could cause ignition break up as the cable moves and makes/breaks contact. This is what I would look at
[Re: Scott Carl]
#2149366
09/07/16 02:16 AM
09/07/16 02:16 AM
Posts: 3,344 Central TX
roe
Central TX
Also along the lines of with and without Air cleaner, are you sure your linkage isnt contacting the bottom of your air cleaner? I had a problem going smoothly to wide open throttle. Everytime I checked the linkage I had the air cleaner off. Finally had a helper do it while I was underhood with cleaner on and saw it happen. Fixed with a spacer. Long shot but that my 2cents
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
