Steering coupler question **UPDATE** #2147281
09/04/16 01:39 PM
09/04/16 01:39 PM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
1978 W150
Is there a kit available for this style coupler? All I find are the kits for Cars or 79 up trucks.
Re: Steering coupler question [Re: T2R9] #2147897
09/05/16 11:55 AM
09/05/16 11:55 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
That's actually a GM coupler, common of the 70's trucks. Pretty sure kits are out there, look for one for say a 77 K20.
Angry white pureblood male
Re: Steering coupler question [Re: T2R9] #2147900
09/05/16 12:11 PM
09/05/16 12:11 PM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
That would make sense since it is a tilt column and I believe they used GM columns for tilt trucks.
Thanks for the response!
Re: Steering coupler question [Re: T2R9] #2148270
09/05/16 09:01 PM
09/05/16 09:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yes tilt column is gm supplied. But even straight columns used it too.
Re: Steering coupler question [Re: T2R9] #2162310
09/26/16 08:45 PM
09/26/16 08:45 PM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
After some research and trial and error I found the correct replacement coupler. 72-86 Jeep CJ with manual steering is a perfect fit on the 78 power steering gearbox. OMIX-ADA part number 18018.04
Kind of a one year only thing as they went to the standard car style couping in 79.
Re: Steering coupler question [Re: T2R9] #2163440
09/28/16 03:34 AM
09/28/16 03:34 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
GOOD INFO! THANKS
Re: Steering coupler question [Re: T2R9] #2164964
09/30/16 07:42 AM
09/30/16 07:42 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Used on most 70's trucks. Change over was 79 or 80.
Re: Steering coupler question [Re: ruderunner] #2165155
09/30/16 03:12 PM
09/30/16 03:12 PM
dogdays Offline
dogdays  Offline
Many Mopar tilt columns were Saginaw. The non-power steering box in my '64Dog is a Saginaw. That box looks like a Saginaw to me. It should have a big letter "S" cast into the body.
Saginaw Gear was owned by GM but is now a part of Delphi, a separate company.
The point of all this is there may be a bunch of GM cars using that joint.
R.
Re: Steering coupler question [Re: dogdays] #2165348
09/30/16 07:47 PM
09/30/16 07:47 PM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
R.
I agree but finding a kit was next to impossible for any GM product with this joint. Then I happened across the Jeep ones on Amazon and bought both the manual and power steering ones hoping one would fit and worst case I would use the guts to rebuild mine. The manual one fit perfectly so Its as tight as new.
