About to buy a motor, which one would work best? #2147592
09/04/16 10:08 PM
09/04/16 10:08 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I'm about to pull the trigger on a brand new 6.4 Hemi fir my 37 Plymouth pickup. I will be using a 545RFE automatic transmission and a B body 4.10 Dana 60. Both engines are the same price.
Motor #1 has a rear sump pan, automatic flywheel and the exhausts are more straight heading towards the firewall
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2147597
09/04/16 10:13 PM
09/04/16 10:13 PM
Dreaming of the 808
Dreaming of the 808
Motor #2 has more of a mid engine sump, clutch/flywheel for a manual transmission, the exhaust manifolds seem to dump in a more downward direction, it looks like the divers side manifold might have more issues with the steering column
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2147848
09/05/16 10:33 AM
09/05/16 10:33 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
Have you decided on your front suspension yet?
On the Mustang II setup I'm running and the other Mustang II based units I've seen, the crossmember you weld in lines up with the center of the wheels and uses a front mounted rack. The rear sump pan will work with no problem and the center sump would probably work. If you're using some other suspension especially one with a rear mount rack the center sump pan may become a problem.
As far as the exhaust, the exhaust on the second engine looks like it might be a bit wide to fit but that will depend on the height you set the engine at. The exhaust on the first engine might work better but it could get a little tight making the bend required to clear the firewall.
Either one could present a challenge getting the steering shaft(s) connected between the column and the steering rack. One of the things I found on mine was that clearing the back of the block was almost as much of a problem as getting it past the exhaust.
In spite of how it looks it does turn smoothly and with the power rack there is not a lot of strain on the joints. If I ever redo it (or had it to do over again), I would probably look at using a “Steer Clear” box drop and eliminate the upper steering shaft.
http://www.wizardsteerclear.com/
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2147905
09/05/16 12:16 PM
09/05/16 12:16 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think the #1 looks like you have more usable parts on it---and not knowing what kind of truck you are building one other steering option is a rack off a 1/4 midget racer --this puts a steering armature out the drivers side of the cowl and a long drag link to the left front wheel----cuts down on the 3 or 4 joints on the steering shaft....
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2148506
09/06/16 01:35 AM
09/06/16 01:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks to me like motor would be the best choice, and then I would expect to be buying a set of center dump headers. Any hot rod I've ever done made better use of a rear sump pan. Gene
Re: About to buy a motor, which one would work best? [Re: Mike P] #2148520
09/06/16 01:53 AM
09/06/16 01:53 AM
Dreaming of the 808
Dreaming of the 808
Mike, I will be using a Mustang II front suspension
Re: About to buy a motor, which one would work best? [Re: poorboy] #2148522
09/06/16 01:55 AM
09/06/16 01:55 AM
Dreaming of the 808
Dreaming of the 808
Will the headers add additional horsepower? Any link to header suppliers?
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2148974
09/06/16 05:39 PM
09/06/16 05:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Headers might not add much HP, but they make the installation process a whole lot easier. Sorry, no links, too new for my experience. Gene
Re: About to buy a motor, which one would work best? [Re: AZ_A12_BEE] #2149286
09/07/16 12:05 AM
09/07/16 12:05 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
if you don't mind me asking, what does a 6.4 go for these days?
and as far as the pan goes, rear sump always seams to work in early year cars and trucks but center drop also work depending on engine location. with the mustang II style front end and the rack in front of the cross member you usually have good room behind it.
