Temperature gauge accuracy #2126967
08/07/16 07:24 AM
08/07/16 07:24 AM
ROADRCR Offline OP
ROADRCR  Offline OP
I am noticing a large variance in what my temp gauge is showing (205 degrees) vs. what my infrared thermometer is reading (178 degrees) at the thermostat housing. Reading at the radiator cap is 140 degrees. Sending unit is stock (340 LA)connected through new factory wiring harness to an aftermarket (Autometer Pro Comp) temperature gauge. I am thinking gauge needs to be calibrated or a new sending unit. Any suggestions would be greatly appreciated.
Re: Temperature gauge accuracy [Re: ROADRCR] #2126993
08/07/16 10:01 AM
08/07/16 10:01 AM
PA
70Duster Offline
70Duster  Offline
PA
Emissivity is the measure of an object's ability to emit infrared energy. Depending on the color and/or reflectivity of the material you are measuring the temperature of, the temperature gun needs to be calibrated to that material or you will get a false reading. Emissivity is generally as low as zero for an extremely shiny surface to as high as 1.0 for a surface painted matte black.
Unless the temperature gun has been calibrated for the emissivity of the material you are measuring the temperature of, the reading will be incorrect.
I understand some of the cheap IR temperature guns don't even have the ability to calibrate to the emissivity of different materials which IMHO renders them next to useless.
Re: Temperature gauge accuracy [Re: ROADRCR] #2126998
08/07/16 10:33 AM
08/07/16 10:33 AM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Add in reflectivity and the IR readings can be pretty loosey goosey.
Re: Temperature gauge accuracy [Re: ROADRCR] #2127031
08/07/16 11:31 AM
08/07/16 11:31 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My AutoMeter pro comp temp gauge came with a new sender. Yours didn`t?
Re: Temperature gauge accuracy [Re: ROADRCR] #2127084
08/07/16 01:00 PM
08/07/16 01:00 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I agree...should have used the new autometer sensor..that will eliminate a few 'maybe' iassues.
Re: Temperature gauge accuracy [Re: 70Duster] #2127096
08/07/16 01:17 PM
08/07/16 01:17 PM
70Duster, good info! I had no idea & it makes me question how accurate my HF gun is going to be (still in pkg/ain't used it yet)
Re: Temperature gauge accuracy [Re: 70Duster] #2127114
08/07/16 01:45 PM
08/07/16 01:45 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Although i do a lot of temperature measurement,
I held off buying an IR gun until i saw the
Craftsman Pro 1400 unit
That includes a plug and type K thermocouple probe
for fine tuning the emissivity reading
http://www.searsoutlet.com/1400-Degree-N...amp;mode=seeAll
I think the Fluke IR gun also has this feature.
I have now seen $19 IR guns,
and along with "free" Harbor Freight multimeters,
i would not argue that these very inexpensive units have their place in nearly any tool bag that all vehicles ought to have
Re: Temperature gauge accuracy [Re: ROADRCR] #2127122
08/07/16 01:53 PM
08/07/16 01:53 PM
5thAve Offline
5thAve  Offline
You can't get a fully accurate temperature reading checking different surfaces with the temperature gun because the different materials absorb heat differently.
When I was trying to test my temperature gauge I boiled a pot of hot water and checked that and it was pretty accurate, then stuck the sender in the pot and compared what the gauge said to what the gun said and it was pretty close.
Re: Temperature gauge accuracy [Re: ROADRCR] #2127180
08/07/16 03:38 PM
08/07/16 03:38 PM
ROADRCR Offline OP
ROADRCR  Offline OP
Thanks to all. Good info. My IR gun I purchased from the HVAC supply house I work at is made by Fieldpiece which at my cost was around $80. However it does not have emissivity fine tuning. I will look at the Craftsman Pro 1400. Thanks again.
Re: Temperature gauge accuracy [Re: 360view] #2127232
08/07/16 05:07 PM
08/07/16 05:07 PM
PA
70Duster Offline
70Duster  Offline
PA
That sounds like the right kind of setup. But I question the need for the IR gun if you get good temp readings with the type K probe.
I have a type K thermocouple probe that plugs into my multi-meter, I believe it's a GreenLee Meter. It has proven to be extremely accurate and I've never needed an IR gun because I've always been able to accurately measure temperature with the type K thermocouple probe plugged into the multi-meter.
Re: Temperature gauge accuracy [Re: 70Duster] #2147615
09/04/16 10:36 PM
09/04/16 10:36 PM
ROADRCR Offline OP
ROADRCR  Offline OP
Thanks for you advice. I went out an purchased an infrared thermometer with an adjustable emissivity feature. I then contacted the manufacturer of my aluminum radiator to find the grade of aluminum that their radiator was constructed with. They replied that it was 4043 rough aluminum. At that point I began to Google emissivity ratings for the above mentioned. Not knowing enough about what this would translate to I am seeing ratings for oxidized aluminum, polished, plain sheet etc., but nothing that I can understand would pertain to my radiator. Any suggestions on where else I might look to for a more definite answer? Thanks again for the advice, I learned quite a bit about the importance of knowing what I am pointing that device at.
Re: Temperature gauge accuracy [Re: ROADRCR] #2147642
09/04/16 11:20 PM
09/04/16 11:20 PM
Morrow, OH
Morrow, OH
You really can't depend on bare aluminum for good measurements. Tape 2 pieces side by side of flat black electrical tape (or shiny black and scotch brite it real well) and put it on the bare aluminum. Aim your temp gun a couple of inches away from the tape and you will be good to go.
Re: Temperature gauge accuracy [Re: markz528] #2147734
09/05/16 01:14 AM
09/05/16 01:14 AM
You guys are good!
Re: Temperature gauge accuracy [Re: ROADRCR] #2147747
09/05/16 01:33 AM
09/05/16 01:33 AM
Cab_Burge Online work
Cab_Burge  Online Work
You need the proper sending unit for your gauge and then verify it's reading accurate with a good, accurate, heating and air conditioning pocket thermometer scope
I had a high dollar racing 2 5/8 mechanical Auto Meter gauge that red 140 F when the circulating coolant in the radiator was body tempature shock I bought a good pocket thermometer and it read 98F when that stupid Auto Meter racing gauge read 140 F down puke Same thing on two new Stewart Warner mechanical industrial temp. gauges runaway
Always trust and then verify when in doubt up twocents
Re: Temperature gauge accuracy [Re: Cab_Burge] #2147914
09/05/16 12:30 PM
09/05/16 12:30 PM
ROADRCR Offline OP
ROADRCR  Offline OP
I recently installed a matching Autometer sending unit and a Mr.Gasket radiator cap that has a built in temperature display. There is about a 20 degree difference in what the cap displays (190) vs. what the dash gauge shows (210). I will take all the suggestions posted and apply them. In conclusion I will take the cap and put it in a pan of hot water and take the temperature of the water with my radiator thermometer and compare it to the cap for accuracy. Thanks to everyone for your suggestions. Good stuff!
Re: Temperature gauge accuracy [Re: ROADRCR] #2147975
09/05/16 01:42 PM
09/05/16 01:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
if you want an accurate reading you will need an 1/8" thermocouple probe and meter. I put the probe in as close to the sending unit as possible making sure that it is in the coolant but not touching anything. Thermocouples are extremely accurate and respond very quickly. Using a probe extension one can put the meter in the car, drive it around and compare #'s.
My experiences show that if the readings are off, they typically go further out of calibration the warmer the temp. if it's an electrical gauge this can be due to grounds, other electrical issues, the sending unit, or the gauge itself.
Inexpensive meters and probes are available on ebay. Do be aware their are different types of probes with J or K being the most common. There are also different connector styles so heads up on that as well
beer
