Steering coupler question **UPDATE**
#2147281
09/04/16 01:39 PM
09/04/16 01:39 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
1978 W150
Is there a kit available for this style coupler? All I find are the kits for Cars or 79 up trucks.
Re: Steering coupler question
[Re: T2R9]
#2147897
09/05/16 11:55 AM
09/05/16 11:55 AM
Posts: 5,953 ohio
ruderunner
ohio
That's actually a GM coupler, common of the 70's trucks. Pretty sure kits are out there, look for one for say a 77 K20.
Angry white pureblood male
[Re: T2R9]
#2148270
09/05/16 09:01 PM
09/05/16 09:01 PM
Posts: 5,953 ohio
ruderunner
ohio
Yes tilt column is gm supplied. But even straight columns used it too.
[Re: T2R9]
#2164964
09/30/16 07:42 AM
09/30/16 07:42 AM
Posts: 5,953 ohio
ruderunner
ohio
Used on most 70's trucks. Change over was 79 or 80.
[Re: dogdays]
#2165348
09/30/16 07:47 PM
09/30/16 07:47 PM
T2R9
Conway, SC
Many Mopar tilt columns were Saginaw. The non-power steering box in my '64Dog is a Saginaw. That box looks like a Saginaw to me. It should have a big letter "S" cast into the body.
Saginaw Gear was owned by GM but is now a part of Delphi, a separate company.
The point of all this is there may be a bunch of GM cars using that joint.
R. I agree but finding a kit was next to impossible for any GM product with this joint. Then I happened across the Jeep ones on Amazon and bought both the manual and power steering ones hoping one would fit and worst case I would use the guts to rebuild mine. The manual one fit perfectly so Its as tight as new.
