Re: Headlamp Adjusting Nut
[Re: B5Cuda440-6]
#2144124
08/30/16 09:21 PM
08/30/16 09:21 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Rob,
I ordered these Monday - http://www.ebay.com/itm/172074937943?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
I'll compare them to my originals when they arrive Friday, but initially look perfect.
Yes, I ordered extra, well you know....
Tom
68 Charger 70 Cuda
[Re: B5Cuda440-6]
#2144900
08/31/16 09:42 PM
08/31/16 09:42 PM
Posts: 4,115 MD
floyd
MD
[Re: floyd]
#2144918
08/31/16 09:58 PM
08/31/16 09:58 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
I think AMD also has them. Rock Auto lists them but they are not an exact copy. Look like they would work. Nice thing about Rick's and AMD is they also include the spring which seems to often rust (at least they do here at ground zero for corrosion)
[Re: B5Cuda440-6]
#2145842
09/02/16 12:47 AM
09/02/16 12:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
That's my fear as well... I've found the ones from CarQuest pn# 8053015 (6 per box) are pretty much a match for OEM, the other repros on the market are often bright white nylon inserts in the spring steel cage, the carquest's are off white, more OEM looking, the cage and screw are OEM appearing
[Re: DAYCLONA]
#2145919
09/02/16 03:47 AM
09/02/16 03:47 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
That's my fear as well... I've found the ones from CarQuest pn# 8053015 (6 per box) are pretty much a match for OEM, the other repros on the market are often bright white nylon inserts in the spring steel cage, the carquest's are off white, more OEM looking, the cage and screw are OEM appearing Why six per box?
[Re: B5Cuda440-6]
#2146381
09/02/16 08:21 PM
09/02/16 08:21 PM
FC7cuda
Dallas, Texas
The plastic color on the Carquest version appears closer to my 46 year old yellowed original part. The screw is definitely different.
68 Charger 70 Cuda
[Re: B5Cuda440-6]
#2146813
09/03/16 03:00 PM
09/03/16 03:00 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike,
Does the metal retainer on the Carquest nuts look similar to the retainer on the nut Tom posted?
The nylon insert and cage retainer look identical to OEM, just the screw head is slightly different...
