Headlamp Adjusting Nut #2144121
08/30/16 09:06 PM
08/30/16 09:06 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
Does anyone know where I can purchase the headlight adjusting nut that is used on a 70 Cuda? Each car uses 4 (2 per headlamp). Several of mine are broken (see picture below).
Or does anyone on the board have 4 NOS nuts, or really nice originals?
Thanks.
Rob
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2144124
08/30/16 09:21 PM
08/30/16 09:21 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Rob,
I ordered these Monday - http://www.ebay.com/itm/172074937943?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
I'll compare them to my originals when they arrive Friday, but initially look perfect.
Yes, I ordered extra, well you know....
Tom
68 Charger
70 Cuda
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2144169
08/30/16 10:12 PM
08/30/16 10:12 PM
Indianapolis, IN
Indianapolis, IN
Yes please let me know how they compare to the orignal parts. I'm curious as well.
Rob
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2144900
08/31/16 09:42 PM
08/31/16 09:42 PM
MD
floyd Offline
floyd  Offline
MD
Re: Headlamp Adjusting Nut [Re: floyd] #2144918
08/31/16 09:58 PM
08/31/16 09:58 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
I think AMD also has them. Rock Auto lists them but they are not an exact copy. Look like they would work. Nice thing about Rick's and AMD is they also include the spring which seems to often rust (at least they do here at ground zero for corrosion)
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Headlamp Adjusting Nut [Re: floyd] #2144935
08/31/16 10:13 PM
08/31/16 10:13 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145207
09/01/16 09:58 AM
09/01/16 09:58 AM
Indianapolis, IN
Indianapolis, IN
Thanks everyone! Depending on what Tom's e-bay clips look like, I may order them from Resto Rick. I need to give him a call anyway about restoring my heater box (passenger side air outlet lip is broken).
Rob
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145379
09/01/16 02:17 PM
09/01/16 02:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Have no compared the ones from Rick but others I saw were not close and I had to scrounge up originals
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145457
09/01/16 04:14 PM
09/01/16 04:14 PM
Indianapolis, IN
Indianapolis, IN
That's my fear as well...
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145842
09/02/16 12:47 AM
09/02/16 12:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've found the ones from CarQuest pn# 8053015 (6 per box) are pretty much a match for OEM, the other repros on the market are often bright white nylon inserts in the spring steel cage, the carquest's are off white, more OEM looking, the cage and screw are OEM appearing
Re: Headlamp Adjusting Nut [Re: DAYCLONA] #2145919
09/02/16 03:47 AM
09/02/16 03:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Why six per box? shruggy
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145926
09/02/16 04:52 AM
09/02/16 04:52 AM
WA
tman Online content
tman  Online Content
WA
I checked the CARQUEST catalog and that part number does not seem to work.
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2145970
09/02/16 10:21 AM
09/02/16 10:21 AM
Indianapolis, IN
Indianapolis, IN
I also tried the search and it doesn't recognize the part number. I'll have to stop by a local store and see if they can get them.
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146293
09/02/16 06:03 PM
09/02/16 06:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC they retail for about $10-$12 per box of (6)
Mike
Re: Headlamp Adjusting Nut [Re: DAYCLONA] #2146377
09/02/16 08:17 PM
09/02/16 08:17 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Next to original
68 Charger
70 Cuda
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146381
09/02/16 08:21 PM
09/02/16 08:21 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
The plastic color on the Carquest version appears closer to my 46 year old yellowed original part. The screw is definitely different.
68 Charger
70 Cuda
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146736
09/03/16 12:43 PM
09/03/16 12:43 PM
Indianapolis, IN
Indianapolis, IN
Mike,
Does the metal retainer on the Carquest nuts look similar to the retainer on the nut Tom posted?
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146754
09/03/16 01:08 PM
09/03/16 01:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
IIRC on my car I used a repo nut and an original replated screw
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146813
09/03/16 03:00 PM
09/03/16 03:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike,
The nylon insert and cage retainer look identical to OEM, just the screw head is slightly different...
Re: Headlamp Adjusting Nut [Re: B5Cuda440-6] #2146927
09/03/16 07:23 PM
09/03/16 07:23 PM
Indianapolis, IN
Indianapolis, IN
Perfect, that's what I needed to know. Thanks.
