Page 27 of 36 1 2 25 26 27 28 29 35 36
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2130936
08/12/16 10:36 AM
08/12/16 10:36 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That thing's been stiffened up so well......you better go to the dentist and get your fillings checked before you drive it! drumhit It looks like it is almost done, and is going to be really nice. bow
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: JDMopar] #2131380
08/12/16 07:40 PM
08/12/16 07:40 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
It's super stiff. They said they put a jack stand on one corner and lifted the whole car. That was without the trans mount and door bars. Lol. It's getting there which is good. It pays to be patient.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2139638
08/23/16 11:46 PM
08/23/16 11:46 PM
SoCal
SoCal
Transmission is in! boogie
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2146382
09/02/16 08:22 PM
09/02/16 08:22 PM
SoCal
SoCal
Saw the Dart today. I was playing around with different gauges to try to find the best place for a tach and I'm still undecided. Brake lines are almost all done. There are just little small details that need to be massaged out but hopefully it shouldn't take more than 3-4 weeks. luck
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2146524
09/03/16 12:26 AM
09/03/16 12:26 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Looks good.
Check out this shift light, small and can mount about anywhere. Mine is down at bottom of dash near ignition switch. Had it for years and never a problem, simple to put in and change RPM, and it is bright.
https://www.raptorperformance.com/collections/shift-lights
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2151023
09/09/16 01:37 PM
09/09/16 01:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There is a guy on FABO that sells a tach bracket that gets sandwiched between the dash frame and the upper pad.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2151445
09/10/16 01:52 AM
09/10/16 01:52 AM
SoCal
SoCal
Parts were ordered on Wednesday. Steering column we modified to fit the Borgeson box and fuel lines are being created.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2154750
09/14/16 10:43 PM
09/14/16 10:43 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Old, tired, and sometimes broke down. Me, not my car...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2159826
09/23/16 12:28 AM
09/23/16 12:28 AM
SoCal
SoCal
Visited the shop this morning. The car is getting there. Fuel lines almost done. We're just waiting on a couple of fittings. They're installing a remote oil filter as we had some trouble clearing the TTI shorties. Modifying the fan shroud to make it fit and cool better. Some of the pullies needed some spacing to align. Shifter and tach are installed and are great! But she's almost there. They should fire her up for the first time sometime next week or early the following week. Sorry, I forgot to take photos.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2170383
10/08/16 04:41 PM
10/08/16 04:41 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Fire in the hole yet?
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #2170539
10/08/16 08:46 PM
10/08/16 08:46 PM
SoCal
SoCal
I'm supposed to pick it up sometime this week. As in done... done. They're having a problem with the wiring harness under the dashboard.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2171136
10/09/16 09:53 PM
10/09/16 09:53 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Finally, light at the end of the tunnel! Take it real easy on your shakedowns...
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2171173
10/09/16 10:41 PM
10/09/16 10:41 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
So see you at Fall Fling! wave
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: Shoozy] #2171292
10/10/16 01:59 AM
10/10/16 01:59 AM
SoCal
SoCal
Definitely. I barely found collector car insurance for it, but I need the car because I have to have pictures of the car completed from all angles.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: moparpollack] #2171293
10/10/16 02:00 AM
10/10/16 02:00 AM
SoCal
SoCal
If you're going to be out here, give me a holler!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2171312
10/10/16 02:53 AM
10/10/16 02:53 AM
85086
Lil Herman
Lil Herman
85086
I'll be there for sure! wave
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2171937
10/11/16 02:50 AM
10/11/16 02:50 AM
SoCal
SoCal
They're having problems with my parking lights continuously on and the turn signals not working. Driveshaft was just dropped off today. Waiting till tomorrow to figure out when I can pick her up.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2174304
10/14/16 03:19 AM
10/14/16 03:19 AM
SoCal
SoCal
Driveshaft is in, seat belt harnesses are being installed, wiring harnesses are being fixed, and the brand new fuel regulator was bad out of the box. So a new one will show up tomorrow, supposedly. Looks like I'll be picking the car up next week.
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2174820
10/14/16 09:22 PM
10/14/16 09:22 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Fingers crossed!
Re: MuuMuu's 68 Dart... It's a Learning Process... [Re: MuuMuu101] #2178378
10/19/16 03:18 AM
10/19/16 03:18 AM
SoCal
SoCal
The note I got today... "After a long day of tracing wires, repairing connections, and some new pins on several connectors we were able to get the wiring fixed and everything working. The new fuel regulator is installed and test for pressure. We expect to run the car tomorrow. We will bolt in the console and cover the rear seat pan. If shake down goes well, we should have the car ready to go on Friday! I can confirm tomorrow."
