Page 2 of 6 1 2 3 4 5 6
Re: 78 Utiline Build [Re: MoPwer] #2074574
05/16/16 03:59 PM
05/16/16 03:59 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Originally Posted By MoPwer
Originally Posted By 68dodge
Nice truck, looks great lowered. Getting close to setting my 505 in.
Any other pics of your roll bar? Looks pretty tidy.
Here is one for you.
Re: 78 Utiline Build [Re: MoPwer] #2075230
05/17/16 05:13 PM
05/17/16 05:13 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Anyone have a rear sump big block oil pan set up they want to donate or sell?
-78 Utiline (5.7 Hemi)
Re: 78 Utiline Build [Re: 68dodge] #2075507
05/18/16 12:53 AM
05/18/16 12:53 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Nice! Kit or custom?
Re: 78 Utiline Build [Re: MoPwer] #2077595
05/21/16 11:13 AM
05/21/16 11:13 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Kit was from Jegs, cut to fit youself, hoop was very tight to get in.
Re: 78 Utiline Build [Re: MoPwer] #2079017
05/23/16 08:55 PM
05/23/16 08:55 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Anyone successfully use A Body big block Fenderwell headers on their 2wd truck? I'm reading it should work, but no pics.
Re: 78 Utiline Build [Re: MoPwer] #2082242
05/29/16 12:07 PM
05/29/16 12:07 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Not doing fender well headers after all. They make it tough to use a balance pipe.
The biggest truck header I can find is 1-3/4" primaries. Anyone know if there are affordable 1-7/8" that will fit? Some say the B&E headers will fit.
Re: 78 Utiline Build [Re: MoPwer] #2145893
09/02/16 02:06 AM
09/02/16 02:06 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
440 looked good so it is going back together with a set of stock closed chamber heads... For now.
Re: 78 Utiline Build [Re: MoPwer] #2145949
09/02/16 08:33 AM
09/02/16 08:33 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Debating on going straight to ladder bars when I do the 60.
Avoid the ladders for street use. I know its not your rock crawler but ladders do not allow for any articulation. Save those for big tire drag strip use only.
Love the build. Big block in a 78. ☺
Re: 78 Utiline Build [Re: Magnum] #2150160
09/08/16 03:14 AM
09/08/16 03:14 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Yeah, I'm leaning towards bagging the thing. Never had a street vehicle with bags and I understand they ride really well.
Re: 78 Utiline Build [Re: MoPwer] #2179640
10/21/16 10:57 AM
10/21/16 10:57 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Engine is almost ready to go in.
Re: 78 Utiline Build [Re: MoPwer] #2180631
10/23/16 12:48 AM
10/23/16 12:48 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
It's in
Re: 78 Utiline Build [Re: MoPwer] #2180840
10/23/16 02:22 PM
10/23/16 02:22 PM
Alberta
440_Offroader Offline
Alberta
Nice, looks good in there! I like the dual master cylinder set up too! biggrin
Re: 78 Utiline Build [Re: 440_Offroader] #2180884
10/23/16 03:49 PM
10/23/16 03:49 PM
Buford, GA
I_bleed_MOPAR Online content
I_bleed_MOPAR  Online Content
Buford, GA
iagree
The dual master cylinder is a very rare option on these trucks. wink grin
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 78 Utiline Build [Re: I_bleed_MOPAR] #2181195
10/24/16 01:00 AM
10/24/16 01:00 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Yeah, only the SCCA trucks had them
iagree
Tim
Re: 78 Utiline Build [Re: MoPwer] #2245707
02/02/17 01:38 AM
02/02/17 01:38 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Well, it runs. Had to rebuild the carb.
Scrapped the header idea for now. Found a set of manifolds.
Couldn't find the correct shift and kick down linkages, so I got some from other vehicles and made it work.
Next will be to narrow the Dana 60. Then I can have the driveshaft shortened and then fill the trans with fluid.
Re: 78 Utiline Build [Re: MoPwer] #2246106
02/02/17 08:49 PM
02/02/17 08:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good to see.
Got me hyped about working on my '76.
I have mechanical Aptitude.
I can screw up anything.
Re: 78 Utiline Build [Re: MoPwer] #2247500
02/05/17 01:02 AM
02/05/17 01:02 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Got the difficult part of the exhaust done tonight. Next the pipe to the muffler. 2 x 2.25" to 3".
Re: 78 Utiline Build [Re: MoPwer] #2247913
02/05/17 06:20 PM
02/05/17 06:20 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Replaced the ammeter with a volt meter.
Re: 78 Utiline Build [Re: MoPwer] #2248020
02/05/17 09:00 PM
02/05/17 09:00 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Exhaust is done. Put in a wideband O2 sensor for easier tuning.
Cleaned up the 60.
Re: 78 Utiline Build [Re: MoPwer] #2248120
02/05/17 11:26 PM
02/05/17 11:26 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
60 housing is cut down to length. Just need to burn it in.
