DROP IN ROLLER LIFTER SB
#214541
02/05/09 03:03 AM
02/05/09 03:03 AM
Posts: 301 central Pa.
71Pan
central Pa.
Re: DROP IN ROLLER LIFTER SB
[Re: 71Pan]
#214542
02/05/09 06:44 AM
02/05/09 06:44 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
why not factory rollers?
late model trucks with the 5.2s and 5.9s had roller lifters stock.
**Photobucket sucks**
[Re: patrick]
#214545
02/05/09 10:39 AM
02/05/09 10:39 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
stock roller lifters won't work in older blocks.
contact board member OU812. he has some nice ones from comp cams that aren't in their catalog yet.
I believe the ones Brian (ou812) sells are retrofit solid roller lifters? His are nice because the link bar is toward the center of the engine so no grinding on the block needed.
[Re: 71Pan]
#214547
02/05/09 10:40 AM
02/05/09 10:40 AM
Posts: 32 Brunswick Ohio
dusta340
Brunswick Ohio
I need some opions on best drop in solid roller lifter sb.No bushing of block and min. clearencing
you will have to grind on the lock a little. but i used a comp solid body roller lifter no bushing no bs i ran it for 2 years no problems. if you want i can get you part numbers for the lifters i used
[Re: dusta340]
#214548
02/05/09 10:54 AM
02/05/09 10:54 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
The lifters he's referring to, have the link bar to the inside.......away from the block.I doubt if they require clearancing at all. Uncovering the oil galley, is a whole different problem. Running smaller lift lobes with higher rockers would remedy this but, high ratio rocker arms for SB Mopars is big $$$$. The last 2 blocks I had bushed cost me $511.00 apiece.
[Re: CJK440]
#214554
02/05/09 12:48 PM
02/05/09 12:48 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The 828-16s are the old number. I dont think they superceded. Check with Brian, he actually helped them deveolp them as I understand it. In any event, I don't run a solid roller lifter without bushings. Ever.
[Re: prochamp]
#214558
02/05/09 06:08 PM
02/05/09 06:08 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
doug herbert sells drop in rollers for about half the cost of the comps.part#hertev.
Those are what I run as well. $219.00 a set and no grinding and no bushing or tubing. Just drop them in with the link bar toward the sides of the of the lifter valley (backwards) and thats it. Ive been running mine on the street and at the track on a car that runs 10.30's on motor and 9.20's on spray with no issues. Good products.
[Re: a408swinger]
#214560
02/06/09 02:14 AM
02/06/09 02:14 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
I think they recently jumped to about 265 at Doug Herbert, IIRC.
I think Chet Herbert still has them listed at $218.
