Too Much Crankcase Pressure Cause the Engine to Stall?
#214522
02/05/09 01:52 AM
02/05/09 01:52 AM
fury4speed
In a previous post I asked: my car was stalling when coming to a stop , I tried different metering rods , checked the timing , car runs fine but still stalls when coming to a stop , Engine other wise Idles fine , Manual Trans Car , anyway I just posted a problem about crankcase pressure , I only have a PCV valve and no breather , and you can here the pressure escaping when the Engine is shut off , anyway would that cause the Engine to stall , maybe the pressure is feeding back throught the carburetor , just a thought.
Re: Too Much Crankcase Pressure Cause the Engine to Stall?
[Re: fury4speed]
#214523
02/05/09 02:22 AM
02/05/09 02:22 AM
RapidRobert
Check your float level. Take out your idle mixture screws & blast a 2 second shot of starting fluid in each passage & reinstall screws & count # of turns to get them back to where they were & shoot some starting fluid into your air bleeds on the top of the carb.
[Re: RapidRobert]
#214524
02/05/09 02:42 AM
02/05/09 02:42 AM
Posts: 3,903 Oregon
hooziewhatsit
You didn't mention it, but manual brakes, or power brakes?
Apparently a leaky diaphram can cause a big enough vacuum leak it can kill the engine, which happens when you hit the brakes coming to a stop.
-Dave
[Re: fury4speed]
#214526
02/05/09 06:28 AM
02/05/09 06:28 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
AFB, TQ? Does it have the manual tranny dashpot in good working order?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
