Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214508
02/06/09 01:05 PM
02/06/09 01:05 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
End 1
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214509
02/06/09 01:06 PM
02/06/09 01:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
End 2
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214510
02/06/09 01:07 PM
02/06/09 01:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Casting Number should anyone want to look for a set.
*Ryan, feel free to use these pics on your site if you like.
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214511
02/06/09 01:19 PM
02/06/09 01:19 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
After you port match it yes... any W2 intake as long as the roof in port of head did'nt go too high to be able to get a good seal. That head is a W2 width & bolt pattern & port height out of box. Just needs manifold port matched to the rectangle port shape/size.
Last couple sets of Diamonds I saw ran used an Edelbrock Victor W2 intake.
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: RyanJ] #214512
02/06/09 01:30 PM
02/06/09 01:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, cool, thanks Ryan.
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214513
07/21/09 08:36 PM
07/21/09 08:36 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
You never posted any "AFTER" pictures.
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: S/ST 3040] #214514
07/21/09 08:46 PM
07/21/09 08:46 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I was very intrigued when you first posted about these.
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214515
07/24/09 04:23 PM
07/24/09 04:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After Porting
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214516
07/24/09 04:24 PM
07/24/09 04:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Close Up Intake Port
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214517
07/24/09 04:28 PM
07/24/09 04:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Exhaust Side After Porting
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214518
07/24/09 04:29 PM
07/24/09 04:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Close up Exhaust Port
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214519
07/24/09 04:30 PM
07/24/09 04:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Chambers
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214520
07/24/09 04:30 PM
07/24/09 04:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Front End
Re: Had Some Aluminum SB Heads Ported- Flowed B4&After [Re: ScottSmith_Harms] #214521
07/24/09 04:31 PM
07/24/09 04:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Rear End
