1983 d150 360 swap #2144333
08/31/16 01:34 AM
08/31/16 01:34 AM
wheeling, west virginia
W
wvjohn Offline OP
wvjohn  Offline OP
W
i have a 1983 d150 with a 6 cyl 4 speed od trans. i want to swap a 360 into it retainiing the 4 speed. what will be required to do this.any help is appreciated.
Re: 1983 d150 360 swap [Re: wvjohn] #2144338
08/31/16 01:42 AM
08/31/16 01:42 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
The 360 needs...
2wd motor mounts
rear sump oil pan
correctly balanced flywheel
sb bell housing to mate to your 4 speed
different radiator
Re: 1983 d150 360 swap [Re: wvjohn] #2144750
08/31/16 06:37 PM
08/31/16 06:37 PM
Sunny South
N
Noah Zarq Offline
Noah Zarq  Offline
N
Sunny South
Went through this 4 years ago. You'll also need:
radiator
radiator hoses
fuel line
clutch linkage
clutch disc
pressure plate
exhaust
alternator and power steering brackets
It's fairly straightforward. Your transmission will survive just fine (I'm assuming its the A833OD like mine has)behind the 360 if you don't drag race it or try to do anything extreme.
Re: 1983 d150 360 swap [Re: Noah Zarq] #2145114
09/01/16 01:11 AM
09/01/16 01:11 AM
W
wvjohn Offline OP
wvjohn  Offline OP
W
thanks for the info. maybe it will also help someone else trying to do the same swap.thanks again, john
