Temp Gauge #2142373
08/28/16 11:34 AM
08/28/16 11:34 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Have 51 miles on 70 Challenger after 15 year rebuild. Have 180 thermostat and after driving couple miles the temperature gauge does not go above the 1st white mark by cold. Check around water pump with temperature scan gun and it reads about 175. Should the gauge needle be up higher ? ?
thanks
Re: Temp Gauge [Re: ct440rod] #2143943
08/30/16 03:47 PM
08/30/16 03:47 PM
Andrewh Offline
Andrewh  Offline
I have had them read a bit different for each car and sensor you have in the block.
they usually have a bracketed area that it falls between for "normal" temps.
you could check the sensor or wiring, or even voltage to the gauge and see which might be off.
Re: Temp Gauge [Re: ct440rod] #2144181
08/30/16 10:29 PM
08/30/16 10:29 PM
BlueRacer69 Offline
BlueRacer69  Offline
thanks
I would say YES. I didn't have a Challenger but I did have a brand new 69 Dart GTS back then. My temp gauge would always read right about 1/2 way/or right about in the middle of the gauge after the car was warmed up.
Re: Temp Gauge [Re: ct440rod] #2144273
08/30/16 11:59 PM
08/30/16 11:59 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You did'nt state the engine size..Is the 180 stat the correct factory value for your engine ??? As other's have suggested it's a matter of matching all the new components together and seeing where "normal" falls on the gauge for a known given temp..
Were the gauges rebuilt ???
Re: Temp Gauge [Re: ct440rod] #2144310
08/31/16 12:47 AM
08/31/16 12:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think from the factory the car would have a 192 in it
Re: Temp Gauge [Re: Morty426] #2144426
08/31/16 09:46 AM
08/31/16 09:46 AM
MI, Livingston
P
plymth70 Offline
plymth70  Offline
P
MI, Livingston
Factory gage use factory sending unit, Auto meter use auto meter sending unit
Re: Temp Gauge [Re: ct440rod] #2144447
08/31/16 10:46 AM
08/31/16 10:46 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Test the gauge (w/key off) by pulling the sending unit wire and grounding it. Turn key on and watch gauge, but don't let it peg too long! If it goes all the way to hot, your sending unit is bad/wrong. If it doesn't go all the way, gauge is bad. Assuming your other dash gauges are working, the dash voltage limiter is working correctly.
Re: Temp Gauge [Re: screamindriver] #2144480
08/31/16 11:28 AM
08/31/16 11:28 AM
BlueRacer69 Offline
BlueRacer69  Offline
[quote=screamindriver]You did'nt state the engine size..Is the 180 stat the correct factory value for your engine ??? As other's have suggested it's a matter of matching all the new components together and seeing where "normal" falls on the gauge for a known given temp.. My 69 Dart was all stock, as I stated it was brand new with a 383 motor.
Were the gauges rebuilt ??? [/quotte]
Re: Temp Gauge [Re: ct440rod] #2144492
08/31/16 11:46 AM
08/31/16 11:46 AM
BlueRacer69 Offline
BlueRacer69  Offline
My 69 Dart GTS was all stock back then, (it was brand new), with a 383 motor and 391 gears. Temp gauge needle always went to 1/2 way between cold & hot when engine was warmed up. I'm guessing yours should too if everything was in sink. I think all 70 Challengers came new with 195 stats.
Re: Temp Gauge [Re: screamindriver] #2145271
09/01/16 11:50 AM
09/01/16 11:50 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Above post is where you need to start first....
Re: Temp Gauge [Re: ct440rod] #2145554
09/01/16 06:04 PM
09/01/16 06:04 PM
Andrewh Offline
Andrewh  Offline
It really doesn't matter what they read in the day.
it really is just a resistor. you have to figure out where you are different and change it so it reads where you want.
Voltage, sender, wiring and gauge are your variables. one or all might be off. Till you test you don't know.
Re: Temp Gauge [Re: BlueRacer69] #2145611
09/01/16 07:34 PM
09/01/16 07:34 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Standard thermostadt in 1970 was a 190..
Just my $0.02... wink
Re: Temp Gauge [Re: ct440rod] #2146543
09/03/16 12:48 AM
09/03/16 12:48 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Mine worked fine. Put a brand new motor in but used old water pump, sending unit, wiring etx and now it just goes to the first mark but doesnt fluctuate. I bought a new sending unit to plug in and hopefully that fixed the problem.
Re: Temp Gauge [Re: ct440rod] #2147197
09/04/16 10:33 AM
09/04/16 10:33 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
440 Magnum. Problem with adding resistor is I need less resistance to get needle to move farther. . Correct ? ? Have new sending unit,180 thermostat, have old sending unit maybe I can check resistance on that at 180 degrees.
Re: Temp Gauge [Re: ct440rod] #2147256
09/04/16 12:55 PM
09/04/16 12:55 PM
Andrewh Offline
Andrewh  Offline
yes, less resistance moves it further up the gauge face.
if you are referring to my post. I didn't mean add one, I meant the sending unit is one.
but things like the wiring, connectors can add resistance.
bulkhead connector and poor connections.
but also the dash VR giving less than 5 volts could cause issues.
things to check. a different sending unit could give different values too.
