Shift 727 into neutral or leave in third after 1/4 mile pass #2144322
08/31/16 01:03 AM
08/31/16 01:03 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Any harm to clicking it to neutral?
My valve body is a Cheetah manual fwd. pattern with LBA.
'63 Dodge 330
11.19 @ 121 mph
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144356
08/31/16 02:24 AM
08/31/16 02:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I leave mine in third but thats because it is a reverse manual valve body and I would have to push the shifter back through second and first which I wont do. It should be no problem with yours. I know when I raced my 4-speed years years ago the first thing I did after passing the finish line was push in the clutch and put it in neutral. Ron
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144365
08/31/16 03:03 AM
08/31/16 03:03 AM
Leave it in gear up twocents The Chebby guys will tell you to ALWAYS put into nuetral after you let off at the end of the race, which is a bunch of hooey down
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144370
08/31/16 03:23 AM
08/31/16 03:23 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Division 6 race at Seattle, I watched eliminations from the finish line, only about a dozen drivers left it in gear after the finish. Whatever that means to you.
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144377
08/31/16 03:38 AM
08/31/16 03:38 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Some valve body builders say you can, some say you can't. Don't know the answer on the particular piece. I would call Turbo Action and ask them. A reverse valve body with a clean neutral and a PPP shifter allows what you are looking for. I've always favored getting the trans into neutral if it can be done safely.
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Cab_Burge] #2144392
08/31/16 06:14 AM
08/31/16 06:14 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Care to explain why?
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144434
08/31/16 10:20 AM
08/31/16 10:20 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I try not to post unless I have first hand knowledge but, I "believe" the valve bodies marketed as "clean neutral" Leave the front "direct drum" clutch applied when clicked in to neutral. Since the direct clutches are splined to the input shaft, there is no chance of over spinning the front drum as long as engine is running. Standard NON clean neutral valve bodies release both front "direct" and rear "forward" clutch packs in neutral which can leave front drum exposed to over spinning and possible "boom" we hear about from time to time. I run an A&A RMVB with a brake "NON-clean-N" so have no choice twocents
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144446
08/31/16 10:45 AM
08/31/16 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most guys that run alum rods go to neutral to
save life on the rods... if you want its no
problem... I used the engine to slow mine down
until the conv disengages.. but I had a reverse
pattern
wave
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144488
08/31/16 11:38 AM
08/31/16 11:38 AM
Minn
SportF Offline
SportF  Offline
Minn
If I am in the lane next to you, please don't.
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144496
08/31/16 11:48 AM
08/31/16 11:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
We have a super long uphill shutdown here. I roll off the throttle and leave it in gear. Willwood wants good money for brake pads so I use the entire shutdown lol.
I agree with SportF, how many top end accidents are caused by messing up the shift to neutral?
68 Barracuda Formula S 340
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Bad340fish] #2144504
08/31/16 12:00 PM
08/31/16 12:00 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I always use the second turnoff and apply and release the brakes a couple of times (comes from running drum brakes and preventing fade!) I try to be easy on equipment and engine braking does help me slow down.
I have reverse lockout as well so their is no chance of "Messing up the shift to neutral."
'63 Dodge 330
11.19 @ 121 mph
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144509
08/31/16 12:10 PM
08/31/16 12:10 PM
an8sec70cuda Offline
I NEED engine braking to slow my sled down!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144529
08/31/16 12:57 PM
08/31/16 12:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
leave it in 3rd. No reason to go to N...
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Cab_Burge] #2144542
08/31/16 01:27 PM
08/31/16 01:27 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
At least with a TH400 you have to have a clean neutral VB or you risk over revving and exploding the direct drum I believe.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144574
08/31/16 02:42 PM
08/31/16 02:42 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I leave mine in 3rd.
Years ago I saw a car come back in parts because the driver found reverse after the lights.
72 Plymouth Roadrunner 11.08@123.25
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Monte_Smith] #2144580
08/31/16 02:50 PM
08/31/16 02:50 PM
Many different reasons for my preferences, one is sticking the shifter into reverse at 117 MPH ONCE in a 1968 Hemi GTX tskAnother is LBA reverse maual V.B. tsk
The rod to stroke ratio on Chebbys compared to Mopars and several other reason shruggy
Saving The older aluminum rods by reducing the RPM at the end of the run was the main reasons most drag racers like to push the clutch in or stick it into nuetral work I've never owned or race a aluminum rod motor shruggy Maybe some day work
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144583
08/31/16 02:55 PM
08/31/16 02:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Going from 4th (or 5th) in a stick car is a different animal than tossing it in -N- in an auto. Let it help you slow down (unless it "free wheels")
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: GY3] #2144603
08/31/16 03:14 PM
08/31/16 03:14 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Huh, some interesting comments and thoughts, but few of them based on fact. First, the reason some valve bodies have a "clean" neutral is because they are reverse pattern. So to be able to neutral the car and not go back through the gears, the "clean" spot is added. Has nothing to do with other things applied for drum speeds of whatever.
You find reverse in the lights?.........why don't you have a shifter with a reverse lockout.
You need engine braking to stop at your track........use that pack thing you have mounted on the deck lid.
Engine braking is uneeded wear and tear on the motor. You'd rather do that as buy brake pads, that's fine.
If possible in the car I am driving, it gets put in neutral and the motor killed at the stripe on every pass. Coast to a stop, gather the chute if used, take my gear off. Then fire motor and drive back, or wait for tow vehicle depending on type car
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Monte_Smith] #2144616
08/31/16 03:27 PM
08/31/16 03:27 PM
None of the Stockers or bracket cars I had or drove needed chutes to stop shruggy As far as that stocker it had the stock console floor shifter with a manual reverse valve body(no clean nuetral valve bodys invented back then shruggy) I shifted it back into 2nd once the motor started to rev up and started to bounce the rear tires so I pulled it back into 2nd gear and then put it back into 3rd gear, I never did that again in that car tsk Marv Ripes put a LBA manual reverse valve body in my old stocker 1963 M.W. push button tranny, I didn't know he had done that and it would try to grab 1st gear when putting the car into nuetral at the end of the runs shock I was at the March meet when that happened the first time and managed to call his shop and ask what the heck was going on, they explain the new reverse LBA V.B.theory and said to not do that tsk I stop doing that and have ever since thumbswork
Re: Shift 727 into neutral or leave in third after 1/4 mile pass [Re: Monte_Smith] #2144660
08/31/16 04:29 PM
08/31/16 04:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
some of us don't have cars anywhere near fast enough for a chute...lol
