ProStart Pep Boys Starters #2143806
08/30/16 12:40 PM
08/30/16 12:40 PM
Port Reading, NJ
roadrunner7070 Offline OP
Port Reading, NJ
Anyone have any experience with the ProStart starters from Pep Boys? My 70 RR needs a new starter and Pep Boys has 25% off. I can get for $46. Has limited lifetime warranty.
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2143908
08/30/16 02:48 PM
08/30/16 02:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Probally a reman.Is it a mini or the big stock one? We used soem of their remans at the shop and they were pretty good.Rocky
Chrysler Firepower
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2143981
08/30/16 04:33 PM
08/30/16 04:33 PM
Port Reading, NJ
Port Reading, NJ
Yes Rocky. It is a reman. I had the choice of the mini or the big stock one and I bought the big stock one. ood to know you had good luck with them.
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2143990
08/30/16 04:48 PM
08/30/16 04:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We only had some problems with AZs remans.It still wasnt bad.As for a mini no way would I ever use the stock one .Only way was if it was showing for points.My reman mini from Advanced has been in close to 20 years.Still going strong .Knock on wood.Rocky
Chrysler Firepower
Re: ProStart Pep Boys Starters [Re: therocks] #2143999
08/30/16 05:11 PM
08/30/16 05:11 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
That's the coolest thing about mopars is the noisy starter...
LOL
Re: ProStart Pep Boys Starters [Re: minivan] #2144008
08/30/16 05:30 PM
08/30/16 05:30 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Look at the back of several starters and learn how to identify the higher horsepower ones from the low HP starters. It's visibly easy to see that the longer unit is the better one. I wish I had a picture to show you but I dont. I've had good luck ordering ones for a 1995 dodge daykota with a 360 engine. I always open up the box right at the counter before I leave the store. If I remember right one is 1.8 HP and one is 1.5 but I may be wrong
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2144439
08/31/16 10:30 AM
08/31/16 10:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Racer I believe you are correct.The 360 ones are supposedly better.The old 2 ton starters are the same.The longer ones are supposedly hi output ones.I have some of both here.Probally had 10 or 20 but my sons were scrapping and tossed a bunch along with alternators, intakes,radiatorrs etc.Once you put a mini in you will never want a clunky old style.Let alone they crank lots faster.Rocky
Chrysler Firepower
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2144443
08/31/16 10:41 AM
08/31/16 10:41 AM
md
mopars4ever Offline
mopars4ever  Offline
md
It seems like any of the reman starters are a shot in the dark. It took two Autozone starters until I got a good one. If it`s easy to change out then go for it. But the limited lifetime warranty is misleading IMO. I had a new monroe shock go bad and Advance Auto said it was a one time replacement. That was it. I guess thats what the limited part means.
Re: ProStart Pep Boys Starters [Re: roadrunner7070] #2144490
08/31/16 11:44 AM
08/31/16 11:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We replaced tons of remans at the shop.Never really had any problems.AZ seemed like they had the worst and even they werent very bad.Advanced we did a lot of buisness with.Very few problesm with anything.Same with warranty.My kid works there as parts pro so I get brakes , ign wires etc taken care of.Even before he worked there we got warranty taken care of.Rocky
Chrysler Firepower
Re: ProStart Pep Boys Starters [Re: mopars4ever] #2144592
08/31/16 03:02 PM
08/31/16 03:02 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Consider yourself lucky. I bought a set of brake pads back to Advance with the limited lifetime warranty and was told normal wear is excluded. They wouldn't give me another set. When I told them AZ has exchanged pads in the past they gave them to me. Depends who is behind the counter .
