Mini tube question #2142533
08/28/16 04:08 PM
08/28/16 04:08 PM
Cottage grove, or
Camron Offline OP
Camron  Offline OP
Cottage grove, or
Does anyone make a mini tube kit or wheel tubes at least for a 1970 barracuda? Wanting to get stock looking bigger ones if I can
Re: Mini tube question [Re: Camron] #2142543
08/28/16 04:29 PM
08/28/16 04:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you mean "tub" where the rear wheels go??? Or is there some type of "tube" I am unaware of work
Must mini tubs are custom made but US cartool might have them shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mini tube question [Re: Camron] #2142631
08/28/16 06:58 PM
08/28/16 06:58 PM
Two choices on your stock rear wheel tubs, have someone widen them or replace them altogether to new drag race tubs shruggy Keeping the stock look from the inside of the trunk makes it a lot harder is what I think work To do that you will need some stock rear tubs from another car so they can be split and widened scope Some guys will remove the inner sides from the pinch joint and make thier own custom inners to the inner frame rails, that works good also work up
My 1970 Cuda race car has large race tubs in it so the largest rear darg tires(16x33x15) can fit in them, the 1/4 panel opening where enlarged also shruggy
Good luck on your deal,let us knwo what you decide to do thumbs
