Re: Anyone here install windshield ?
[Re: 71rm23]
#2142462
08/28/16 02:05 PM
08/28/16 02:05 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Orignal windshield. Yeah I don't remember if still have the Lil rubber wedges that windshield sets on or not......let just say I don't. Where can I come up with those at? 71 RR here. I don't have the rubber spacers (lost) and be interested on where to get them as well or ideas on what to use instead. Also, on the butyl tape. Was there a 3/8" in the front and 5/16" for the rear? Setting blocks should come with the butyl tape kit.. If not, an Auto Glass shop should have some no problem.... 99% of the time 3/8 front, 5/16 rear.... Make sure you get some WS primer and apply it to the area of the glass and the pinchweld where the butyl tape kit sets.... VERY IMPORTANT.... Two people should be able to hold the glass by its edge with your fingers. One hand on the bottom and the other holding the side of WS. Communicate with each other to get an equal space on both sides, from each A pillar while setting the bottom.... It should set on the rubber/plastic setting blocks.. THEN together set the top down into the tape kit..... Apply light pressure to push the ws into the tape kit.. It wont smash it down flat, and its not supposed to , but it does need seal to the tape kit.. You can microwave the kit somewhat to soften it JUST A LITTLE.. I would try 30 seconds at a time until you soften it or just warm it a bit... It will help with the bond.. If its really hot out, disregard..... You are dealing with a used WS... Getting it out is the hardest part... BUT there are LOTS of little tiny pits that will run ( glass will crack) so be carefull not to twist the WS or stress it while handling or installing... Good luck
[Re: toplescuda]
#2142642
08/28/16 07:21 PM
08/28/16 07:21 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I don't have to use primer being I just had the car painted (with glass out)correct??? Car was blasted in window channels to bare metal before paint prep
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2142693
08/28/16 09:00 PM
08/28/16 09:00 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
So it has to have it even if surface is clean then. Guiess sell it at parts store also?
[Re: toplescuda]
#2142735
08/28/16 09:56 PM
08/28/16 09:56 PM
minivan
Eugene, Oregon
3M used to make the black GLASS PRIMER we used back in the day..
I have seen a clear type used but have never used it.....
YES a special primer for glass install... It has NOTHING to do with paint.... Really important to bond the tape kit to the painted metal pinchweld.....
[Re: moparmarks]
#2142737
08/28/16 09:58 PM
08/28/16 09:58 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I use 3/8" and the front and 5/16" on the rear. On the spacers they are like 3/16x3/16x1. Don't know if anyone is making them. Possible pic with tape measure?? Will be going into 71 charger if matters If had some good pics I could prob by make some. Ya know the old saying. Pic worth thousand words lol
[Re: toplescuda]
#2142923
08/29/16 03:32 AM
08/29/16 03:32 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Yep no gasket on 71 b body
[Re: toplescuda]
#2143172
08/29/16 02:59 PM
08/29/16 02:59 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Years ago I worked in a wrecking yard and we sold windshields. We had all the tools to take out the gasketed and glued-in windshield and we still broke half of them. Unless you are determined to have a "numbers matching" windshield to go with the spare tire that has "original air" in it, have a pro install new glass. It probably will look better and have a guarantee by the installer. JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: wannadrag]
#2146964
09/03/16 08:26 PM
09/03/16 08:26 PM
Posts: 1,018 Missouri
MOBodyman
Missouri
Last stuff I bought the spacers came with it. The 3M kits I buy at the parts store have spacers included too. I think I still have a bunch of spares in a drawer at the shop. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
[Re: toplescuda]
#2147058
09/03/16 11:19 PM
09/03/16 11:19 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I haven't had a chance to look at a kit yet. I need to check it out. Thank you
