Re: trans cooler install - any pics?
[Re: mopars4ever]
#2141498
08/26/16 09:30 PM
08/26/16 09:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Don't bother going to the hardware store asking for Adel clamps, you'll get the Nipper look.
[Re: mopars4ever]
#2143900
08/30/16 02:43 PM
08/30/16 02:43 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
The parts-store hardline tubing uses male IF (inverted flare) fittings, so you'll need 1 or 2 elbows: one to adapt OEM tube to new line, and maybe another for the radiator for the new line going back into the tank. If you can get a tight enough bend on the new tube, you may not need that 2nd elbow. If your parts store doesn't have the elbows you need, there's McMaster-Carr, Dorman, and others. Might want to buy an extra tube or two - it's only about $7 per stick - for mockup & playing with bends. Take your time making it look clean, avoiding sharp edges, and locating any clamps. Attractive plumbing & wiring are nice details too often overlooked.
